can you wash and clay at the same time?
You can clay with the soap you're using, just make sure that you do a rinse before claying. Rinsing off all the dirt that you were washing with. Claying will remove the wax but will not harm the clear coat. Make sure you wax after claying
Keep in perspective.....Clay is an abrasive...I always recommend polishing after claying, as clay will micro mar the surface. Clay is a very productive product when used as directed. I dont fall prey to "having" to use a dedicated lube though. Like others, I simply use the clay with water while rinsing. Its not as slippery, but my belief is theres a fine lube when using a lube. If the surface is too slick, the clay isnt grabbing pollutants. Is the surface isnt slick enough, you stand the chance of leaving clay residue. Sometimes while claying, if I feel the surface is real dirty, and the clay is real grabby, I'll grab a handful of soapy water and toss it on the surface.
Claying is very important to your car's finish. It removes surface contaminants that if ignored, will cause irreparable damage. You CAN clay while you wash your car, but remember clay is an abrasive. It's safe on your finish, and an abrasive to the harmful particles in your paint. The whole reason for using a dedicated lubricant when you clay is to provide a super slick, slippery layer between the clay and your car's paint, to protect against minor sufrace marring. I love the Meguiar's Quik Clay system . Oh man, is this stuff good. the smell is AWESOME. I feel like a professional detailer every time I use it. The clay is very effective, and the results are incredible. This is definitely my favorite clay system. If you are going to clay while using soap, you still need a slippery layer in between the paint and the clay...you had better use a quality car wash . The synthetic lubricating oils are perfect for claying while washing. If I want to save time, I clay while washing. If I want to do a perfect job, I clay while using a dedicated clay lubricant. If you have more questions, check out how to clean with clay . Remember to use microfiber towels!!
Originally Posted by exceldetail
A little soapy water will provide the exact benefit at better savings....Correct me if Im wrong, but Meguiars "dedicated" detail spray is actually there instant detailer also ??
That's all any clay lube is....it's a quick detailer. There is no such thing as dedicated clay lube..it's a quick detailer in one form or another. With some quick detailers, (mainly Mothers) I find that it smears the clay. I have never had that problem with the Meguiar's stuff.
Water or, water with a little soap will do the same thing....
Not really. A dedicated quick detailer/detailer spray will provide superior lubrication and surface slickness than a soap will. I would only use soap and water if I wanted to do my car quickly. Like I said before. If you want to take time and do it right, use a detailing spray. If you want to do it quickly and risk micro marring, then use car wash soap. It's all up to you.
Skirmich
09-15-2015 06:41 PM
