Best product for fixing light scratches
I de-badeged my bumper a few days ago and there are some light scratches on either side. You can't notice them from 3 feet away but it still bothers me. What would you guys suggest for this type of fix? Thanks!
3G TL/2G MDX Owner
^^what happened to starting with the LEAST aggressive method first?? OP- i'd save the wet sanding method to last ditch effort (esp if you have no idea what you're doing) or a professional.
True, I agree but if it's a scratch, can't really cover it with after market stuff.
I tried them, waste of money to me
Since it's a small scratch, lightly wet sand might fix it I think.
If I was OP, I wouldn't touch those kind of small scratches
MEKO (01-01-2013)
It would he helpful if you had pictures to determine how bad it is. I use a Porter7424 XP DA Polisher using the Orange Pad using Menzeran 4500 polish. Use setting number 5 to start.
I have removed scratches for my customers using this procedure:
http://www.autogeek.net/how-to-remove-scratches.html
Wet sanding isn't for the noob. Try the ScratchX first and stay away from rubbing compound. by TW.
3G TL/2G MDX Owner
a porter cable with polishing compound will make those less noticeable those are just deep enough to stay in the clear coat, but not enough to warrant touch up paint or catch a finger nail.
is that anthracite metallic? the metallic flakes will help hide them a little. i have a few deeper random scratches on small spots on my car. i used a PC and was able to get them less noticeable (you'd have to look for them, or you can only see them in certain light angles). don't wanna take off too much clear coat to level it out.
i'd start with the scratch x 2.0 like i suggested before. then if that doesn't work well enough, find someone with a porter cable dual action polisher to help you out.
3G TL/2G MDX Owner
use a microfiber and a small blob of it...rub vigorously. you may have to repeat a few times. when done reapply wax to protect the area you just rubbed all the protectant off your paint.
CBP will also help hide it as well. get an after shot if you can.
I will in the morning!
Scratch X should help to remove those scratches. If you find scratch X isn't doing the job another off the counter product is Ultimate Compound from the same brand. It's a bit more aggressive and will likely do the job. Like said above. A coat of wax overtop will help afterwards.
If all fails just call a local detailer. Shouldn't cost much (maybe free) to have that area polished out.
Usually small minor scratches have no need for wetsanding. A buffer will take it out perfectly fine.
wusty23jd
09-24-2015 11:41 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
