Anybody use leaf blower?
Old Aug 5, 2008 | 08:34 AM
  #41
Jesstzn's Avatar
Originally Posted by Hpdrifter
anytime you use a product and see the application pad or rag you are using change color you are using an abrasive material and are probably killing the clear coat.....
Not also true .. chemical cleaners in the waxes / sealants can also do the same.
Old Aug 5, 2008 | 08:37 AM
  #42
Jesstzn's Avatar
Originally Posted by jmkiang
Is using the waterblade considered "safe"? Do you rinse it off after each swipe?
Even if you rinse / wipe it after each swipe you can pick up that one grain if grit on the next pass and scratch. And the chanses of that happening are even greater if the previous step was blowing the water out of creavaces with air of some origin.
Old Aug 5, 2008 | 03:05 PM
  #43
CarrieLynn's Avatar
Well, my husband uses a leaf blower to dry off his bike (08 Hayabusa) I used it to dry my TL a few times too, works good, he has one of those backpack ones.
Old Aug 5, 2008 | 09:00 PM
  #44
Hpdrifter's Avatar
Not wanting to step on toes....I'm the new guy here.....but if you remove paint, whether by chemical means or abrasives in the wax/sealant/or polish....you are going to kill the clear coat.......that was my point!
Old Aug 5, 2008 | 11:06 PM
  #45
Jesstzn's Avatar
And if you don't remove the oxidized paint its worse for it than doing nothing.
And the word "kill" isn't appropriate in tha case of polishing .. we aren't performing abortions . The amount of clear removed is miniscule in the scheme of things .
You do more damage to clear with bad wash / dry practices and poor protection than is done with proper polishing.
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
hashbrown
Sep 29, 2015 12:13 PM
Sep 21, 2015 08:44 AM
BookemDanole
Sep 11, 2015 04:53 PM
Scrib
Wash & Wax
26
Mar 29, 2011 12:11 AM
