After using Scratch X
Hi, I have a quick question that I hope can get an answer. I've used scratch X on a few minor scratches on my car and after using it, the paint finish kinda look faded. My question is how do I restore it to the original shine of the rest of the car? Do I wax it after using scratch X? Any comment is greatly appreciated. Thanks.
Former Sponsor
ScratchX is an abrasive polish, which may or may not remove the scratch your after. Keep in mind, it will mar your paint (Microscratch, appears faded). This is due to tha abrasive nature of the product. You now need a polish with less abrasive, to remove the marring you have now introduced onto your surface.
Driver/Detailer
Step 2 doesn't have abrasives in it. It only has fillers and oils and won't fix your marring.
When you used ScratchX, did you work it in until you started hearing a squeaky sound? You have to work it til it gets squeaky and then wipe it off BEFORE it dries. ScratchX's abrasives break down as you work it, so initially it is a swirl remover but by the end it would work as a polish to finish the surface.
After using ScratchX properly, follow up with the Deep crystal step 2 polish. I find that the paint feels dry-ish after scratchX and step2 helps restore the oils.
Former Sponsor
Originally Posted by exceldetail
The step 2 Polish should help you.....
Step 2 doesn't have abrasives in it. It only has fillers and oils and won't fix your marring. After using ScratchX properly, follow up with the Deep crystal step 2 polish.
Driver/Detailer
Patrick... you cut out the important juicy bit. It's like having seared steak but without the meat in the middle.
Step2 doesn't have any abrasives in it. You can hide the marring but after it rains, the marring becomes visible again.
Better to use ScratchX properly to remove the marring and then followup with Step2 to restore the oils.
Or even better yet, get yourself some Propel pads and proper swirl removers!
Former Sponsor
Are you sure the Step 2 DC Polish doesnt have abrasives? I know Step 1 DC paint cleaner doesnt, but why would Megs sell basically non polishing products in a mutli step program?
1 cleans
2 removes fine spiderwebbing
3 protects.....
The Megs DC 3 Step is a very good OTC product, but expect OTC results also.......
1 cleans
3 protects.....
Driver/Detailer
Guaranteed 100% with info from Mike over at meguiarsonline.com that DC2 does not have abrasives. In the consumer line, ScratchX is the swirl remover/abrasive polish, DC1 is the paint cleaner, DC2 is the pure polish/glaze and DC3 is the wax.
Former Sponsor
Now you know why I dont use Megs stuff anymore, nor do I recommend it too often. In my book, polishes should contain abrasives or they lack whats truelly considered the ability to "polish"......And another thing...How the hell can it claim to remove spiderwebbing without abrasives????? This is BS
Driver/Detailer
Yup, I think the consumer line of Meg's products are a bit too conservative. Maybe it's to prevent the uneducated from damaging their car. I've seen my share of people destroying their paint with "Polyglaze Cut-n-Wax" paste wax. I'd hazard a guess that "removing minor spiderwebbing" means either hiding it from your view, or just providing a lube while the pad does all the work.
I now use Meg's only for their #7 glaze and #21 sealant. I'm a Poorboy's poor boy now. Haha.
2016 E350 Sport
You are completely leaving out Megs Professional line of products which has every light to heavy abrasive cleaner/polish you can think of. Megs consumer line is not meant to fix moderate to severe scratches. All polishes do not have abrasives since every paint job does not require it. It makes no sense to polish a flawless finish with an abrasive polish. I do not care about what product someone favors but misinformation is .
2016 E350 Sport
Ferrari Detail
Former Sponsor
#80 as an example, Speed Glaze, which I used for quite some time. The name implies it is a glaze. Sheeeeeeeeeesh, its one of the best polishes Ive used!
#9 Swirl Remover, the name implies it removes swirls. Well in my years of detailing, you cant remove swirls unless you have an abrasive polish (Be it light/med/compound) " #9 Swirl Remover is completely non-abrasive and safe for all paints." Huh??????? Meguiars makes great car care products, but the labels are misguiding.............
2016 E350 Sport
SJ, calling a product a polish that does not contain abrasives is misleading. That should be called a cleaner. And if there claim implies it can remove spiderwebbing, such as DC #2 "polish" states, it leads the consumer to believe that it contains abrasives. Megs has so many products, in the consumer line and Pro line, that are tweeked ever so slightly, its very confusing, thats why I dont use them anymore....
InFaMouSLink
10-30-2015 09:43 AM
SinCityTLX
55
10-11-2015 01:20 AM
Hines57
09-24-2015 01:58 PM
