3m compouund on paint...
Old Nov 13, 2003 | 10:17 AM
jorgev's Avatar
do you guys think this would help gettin rid of overspray on the car???
gotta start watching where i park!
Old Nov 13, 2003 | 10:36 AM
CLpower's Avatar
teh Senior Instigator
clay bars work good to get overspray off
Old Nov 13, 2003 | 10:45 AM
NSXNEXT's Avatar
I'm assuming you're talking about rubbing or polishing.
DO NOT USE THAT ON YOUR CAR.
As CLpower said, go out and buy a claybar.
Old Nov 13, 2003 | 12:17 PM
fusionnv's Avatar
Gimmie my points Biatch!
Re: 3m compouund on paint...
I not sure wat you got, for "over spray" u wet sand then compound. Compound is generally for light scratches, but I wouldn't use it too much because it is dangerous. You can burn your paint or remove too much of it.
Old Nov 15, 2003 | 10:36 AM
Chopsie's Avatar
Beware of leakage
Old Nov 15, 2003 | 02:40 PM
chef chris's Avatar
Homeless
Yes...clay first with plenty of lube...
Maybe even try some bug-tar spray first, just for kicks.
I would not compound/wet sand the car for any reason...
Old Nov 15, 2003 | 08:45 PM
fusionnv's Avatar
Well I did mine results of the pics are:
http://www.acura-cl.com/forums/showt...ighlight=paint
But wetsanding is only need when u have overspraying or drips on the paint from painting. Like if u just sprayed paint on the fender, u do wetsanding. Compound is good but only for the right reasons. Like if you have heavy scratches and oxidation of the paint. It kinda gives u a "second" chance with the paint. detailers use all of these including the clay bar. Which might be just wat you are looking for. But with bar u also have to be very careful, u can scratch the paint if the lube is not applied enough or u haven't folded the bar over. Use as little abbrasives as possible to make your paint last.
atsx1313
Mar 14, 2017 06:08 PM
Steven Vitek
ILX
Jun 7, 2015 01:56 PM
kmarqueling
Oct 10, 2014 02:17 PM
FCVadi
Apr 26, 2014 03:26 PM
mynameisjacob
Jul 3, 2013 12:45 PM
