FAQ: TSX Pricing and General Specs **Updated 8-17-05**
Photography Nerd
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
MSRP & Invoice Pricing
2004 Model Year
U.S.![Patriot](https://acurazine.com/forums/images/smilies/patriot.gif)
AT/MT Non Navi MSRP: $27,035
AT/MT Non Navi Invoice: $24,691
AT/MT Navi MSRP: $29,035
AT/MT Navi Invoice: $26,512
Canada![Canada](https://acurazine.com/forums/images/smilies/canada.gif)
AT/MT MSRP: $34,800
AT/MT Invoice: $32,016
*Navigation was not available in Canada for 2004*
MY05 TSX MSRP/Invoice
AT/MT Non Navi MSRP: $27,560
AT/MT Non Navi Invoice: $25,171
AT/MT Navi MSRP: $29,560
AT/MT Navi Invoice: $26,992
AT Non Navi MSRP: $36,100
AT Non Navi Invoice: $33,212
AT Navi MSRP: $39,400
AT Navi Invoice: $36,248
MT Non Navi MSRP: $34,900
MT Non Navi Invoice: $32,108
MT Navi MSRP: $38,200
MT Navi Invoice: $35,144
2004 Model Year
U.S.
Canada
AT/MT MSRP: $34,800
U.S.
Canada
Photography Nerd
General Specifications 2004-2005
Dimensions (HxWxL):57.3"x69.4"x183.3"
Minimum Ground Clearance (unloaded): 6.2 in (157.5mm)
Curb Weight
Manual: 3230 lbs (1465 kg)
Automatic: 3318 lbs (1505 kg)
Manual with Navigation System: 3241 lbs (1470 kg)
Automatic with Navigation System: 3329 lbs (1510 kg)
Weight Distribution (% front/rear)
Manual: 60/40
Automatic: 61/39
EPA Estimated Fuel Mileage (city/highway)
Manual: 21/29 mpg
Automatic: 22/31 mpg
Fuel Tank Capacity: 17.1 US Gallons (65 liters)
Premium unleaded 91 octane or higher
*Note: Can run on lower octanes in a somewhat crippled mode. Fuel economy and performance will suffer. See sauceman's fuel economy tests: https://acurazine.com/forums/showthread.php?t=23721
Headroom (front/rear)
37.8 in (960 mm) / 37.3 in (947 mm)
Legroom (front/rear)
42.4 in (1076 mm) / 34.2 in (868 mm)
Hiproom (front/rear)
54.4 in (1381 mm) / 54.4 in (1382 mm)
Shoulder room (front/rear)
55.4 in (1406 mm) / 53.5 in (1360 mm)
EPA Passenger Volume
91.0 cu. ft.
EPA Cargo Volume
13.0 cu. ft.
Curb Weight
Manual: 60/40
Automatic: 61/39
Manual: 21/29 mpg
91.0 cu. ft.
EPA Cargo Volume
13.0 cu. ft.
Photography Nerd
Engine Specs
Engine Code: K24A2
Engine Type: Inline 4 cylinder (Aluminum Alloy constrution)
Valve system: DOHC, i-VTEC, 16-Valve
Displacement: 2.4L
Power: 200-hp @ 6800 rpm
Torque: 166 lbs-ft @ 4500 rpm
Redline: 7100 rpm
Fuel Cut: 7400 rpm under load, 5500 rpm no load
Compression Ratio: 10.5:1
Throttle System: Drive-by-Wire
Engine Code: K24A2
Displacement: 2.4L
Redline: 7100 rpm
Photography Nerd
Transmission Specs
Transmission Choices:
- 5-Speed Automatic with Sequential SportShift, Grade Logic Control and lockup torque converter (Code: MCTA)
- Close Ratio 6-Speed Manual with Magnesium Transmission Case (Code: ASU5)
Gear Ratios
1st
5AT: 2.652
6MT: 3.267
2nd
5AT: 1.517
6MT: 1.880
3rd
5AT: 1.082
6MT: 1.355
4th
5AT: 0.773
6MT: 1.028
5th
5AT: 0.566
6MT: 0.825
6th
5AT: N/A
6mt: 0.659
Reverse
5AT: 2.000
6MT: 3.583
Final Drive
5AT: 4.440
6MT: 4.760
Gear Ratios
1st
5AT: 2.652
6MT: 3.267
2nd
5AT: 1.517
6MT: 1.880
3rd
5AT: 1.082
6MT: 1.355
4th
5AT: 0.773
6MT: 1.028
5th
5AT: 0.566
6MT: 0.825
6th
5AT: N/A
6mt: 0.659
Reverse
5AT: 2.000
6MT: 3.583
Final Drive
5AT: 4.440
6MT: 4.760
Photography Nerd
Colors
2004 Exterior:
NH-623M Satin Silver Metallic (US & Canada)
NH-624P Premium White Pearl (US & Canada)
NH-658P Carbon Gray Pearl (US Only)
B-92P Nighthawk Black Pearl (US & Canada)
B-502P Indigo Blue Pearl (Canada Only)
B-507P Arctic Blue Pearl (US Only)
B-522M Meteor Silver Metallic (US Only)
R-81 Milano Red (US & Canada)
2004 Interior:
Ebony w/aluminum trim (US & Canada)
Parchment w/wood trim (US & Canada)
Quartz w/aluminum trim (US Only)
Canada has limited interior/exterior combinations (2004):
SSM/Ebony
PWP/Ebony
NBP/Parchment
IBP/Ebony
Milano Red/Parchment
2004 Exterior:
2004 Interior:
SSM/Ebony
PWP/Ebony
NBP/Parchment
IBP/Ebony
Photography Nerd
Upcomming Model Info
2006: https://acurazine.com/forums/showthread.php?t=24360
Possibility of a turbo model: https://acurazine.com/forums/showthread.php?t=24204
DiamondJoeQuimby
09-10-2015 11:40 AM
nuldabz
09-03-2015 05:49 PM
