FAQ: TSX Pricing and General Specs **Updated 8-17-05**
MSRP & Invoice Pricing
2004 Model Year U.S. :patriot: AT/MT Non Navi MSRP: $27,035 AT/MT Non Navi Invoice: $24,691 AT/MT Navi MSRP: $29,035 AT/MT Navi Invoice: $26,512 Canada :canada: AT/MT MSRP: $34,800 AT/MT Invoice: $32,016 *Navigation was not available in Canada for 2004* MY05 TSX MSRP/Invoice U.S. :patriot: AT/MT Non Navi MSRP: $27,560 AT/MT Non Navi Invoice: $25,171 AT/MT Navi MSRP: $29,560 AT/MT Navi Invoice: $26,992 Canada :canada: AT Non Navi MSRP: $36,100 AT Non Navi Invoice: $33,212 AT Navi MSRP: $39,400 AT Navi Invoice: $36,248 MT Non Navi MSRP: $34,900 MT Non Navi Invoice: $32,108 MT Navi MSRP: $38,200 MT Navi Invoice: $35,144 |
General Specifications 2004-2005
Dimensions (HxWxL):57.3"x69.4"x183.3" Minimum Ground Clearance (unloaded): 6.2 in (157.5mm) Curb Weight Manual: 3230 lbs (1465 kg) Automatic: 3318 lbs (1505 kg) Manual with Navigation System: 3241 lbs (1470 kg) Automatic with Navigation System: 3329 lbs (1510 kg) Weight Distribution (% front/rear) Manual: 60/40 Automatic: 61/39 EPA Estimated Fuel Mileage (city/highway) Manual: 21/29 mpg Automatic: 22/31 mpg Fuel Tank Capacity: 17.1 US Gallons (65 liters) Premium unleaded 91 octane or higher *Note: Can run on lower octanes in a somewhat crippled mode. Fuel economy and performance will suffer. See sauceman's fuel economy tests: https://acurazine.com/forums/showthread.php?t=23721 Headroom (front/rear) 37.8 in (960 mm) / 37.3 in (947 mm) Legroom (front/rear) 42.4 in (1076 mm) / 34.2 in (868 mm) Hiproom (front/rear) 54.4 in (1381 mm) / 54.4 in (1382 mm) Shoulder room (front/rear) 55.4 in (1406 mm) / 53.5 in (1360 mm) EPA Passenger Volume 91.0 cu. ft. EPA Cargo Volume 13.0 cu. ft. |
Engine Specs
Engine Code: K24A2 Engine Type: Inline 4 cylinder (Aluminum Alloy constrution) Valve system: DOHC, i-VTEC, 16-Valve Displacement: 2.4L Power: 200-hp @ 6800 rpm Torque: 166 lbs-ft @ 4500 rpm Redline: 7100 rpm Fuel Cut: 7400 rpm under load, 5500 rpm no load Compression Ratio: 10.5:1 Throttle System: Drive-by-Wire |
Transmission Specs
Transmission Choices: - 5-Speed Automatic with Sequential SportShift, Grade Logic Control and lockup torque converter (Code: MCTA) - Close Ratio 6-Speed Manual with Magnesium Transmission Case (Code: ASU5) Gear Ratios 1st 5AT: 2.652 6MT: 3.267 2nd 5AT: 1.517 6MT: 1.880 3rd 5AT: 1.082 6MT: 1.355 4th 5AT: 0.773 6MT: 1.028 5th 5AT: 0.566 6MT: 0.825 6th 5AT: N/A 6mt: 0.659 Reverse 5AT: 2.000 6MT: 3.583 Final Drive 5AT: 4.440 6MT: 4.760 |
Colors
2004 Exterior: NH-623M Satin Silver Metallic (US & Canada) NH-624P Premium White Pearl (US & Canada) NH-658P Carbon Gray Pearl (US Only) B-92P Nighthawk Black Pearl (US & Canada) B-502P Indigo Blue Pearl (Canada Only) B-507P Arctic Blue Pearl (US Only) B-522M Meteor Silver Metallic (US Only) R-81 Milano Red (US & Canada) 2004 Interior: Ebony w/aluminum trim (US & Canada) Parchment w/wood trim (US & Canada) Quartz w/aluminum trim (US Only) Canada has limited interior/exterior combinations (2004): SSM/Ebony PWP/Ebony NBP/Parchment IBP/Ebony Milano Red/Parchment |
Upcomming Model Info
2006: https://acurazine.com/forums/showthread.php?t=24360 Possibility of a turbo model: https://acurazine.com/forums/showthread.php?t=24204 |
