04 TL Fitment guide....
17inch ------> 17x8 35-40et w/ 235/45-17
18inch-------> 18x8 35-40et w/ 245/40-18
19inch-------> 19x8.5 40et w/ 245/35-19
PCD is 5-114.3 and hub bore is 64.1.
brakes and hubs are not agressive so all design wheels should work fine with these offsets.
***For snow, 16inch regular barrel only. use 235/50-16
***Air sensors are optional.
Sticky me!
Sticky me!
ask and ye shall recieve...
ACURA TL AUTO/6SPD SEDAN 2004-2004
235/45-17 93W BRIDGESTONE 17X8.0 ALLOY +45mm offset 5-114.3 64.1hub bore 12X1.5 NUT 19MM HEAD
COMMENTS: IDEAL FITMENTS:
17X8 35-40ET W/ 235/45-17
18X8 35-40ET W/ 245/40-18
19X8.5 40-45ET W/ 245/35-19
**AIR SENSORS ARE OPTIONAL ON THIS VEHICLE**
MAX TIRE WIDTH: 265 MM
MAX TIRE HEIGHT: 26.30 MM
MAX WHEEL WIDTH: 9.0 INCHES
WIDTH OFFSET WIDTH OF TIRE
7.0 +18/+65 215/225
7.5 +25/+65 215/225/235
8.0 +31/+63 225/235/245
8.5 +37/+56 235/245/255
9.0 +44/+50 245/255/265
18 INCH WHEELS COME WITH A TIRE PRESSURE MONITOR
CONNECTED TO O.E. VALVE STEM.
AIR PRESSURE SENSORS ARE A ONE PIECE UNIT AND CANNOT
BE USED WITH REVERSE BARREL WHEELS
7.0 +18/+65 215/225
Originally posted by Todd@tires.com
D'oh...miscopied....erased.
Boy is this thread made for me...
Question,
I'm getting an 04 tl 6spd in about three weeks and am in the process of looking for new wheels and tires for the vehicle. The problem is that the set I have picked out in a 19 inch size is only available in an 8" width.
Now, considering the optional Acura wheel is an 18x8.5", will the 19x8" wheel look strange on the car?
The bad part of the whole scenario is that I have had my heart set on this particular set of wheels since I first saw the spy photos several months back! But, at the same time, I want to make sure I buy a set of wheels that fit the car correctly!
Thanks in advance for all your help.
Question,
Question,
Question,
next question...
since the recommended tire size for the 18" acc. wheel is 235/40/18, would it look stupid if I still went up to a 245/35/19 tire even though the new wheel itself is .5" narrower (18.8.5 vs. 19x8)?
Thanks again.
Thanks again.
next question...
Thanks again.
next question...
Thanks again.
Now,
with an 04 TL (6spd) will the offsets be any different from the auto since the front calipers stick out so much further since they're brembos?
Specifically, will a 40 offset fit on the car in a 19x8.5" size?
Re: 04 TL Fitment guide....
Sticky me!
Sticky me!
Now,
Now,
Todd do you have wheels that have the caliper clearance to fit the 6MT?
Todd - PM'd you
Todd - Please take a look at your PM. I've got a short question on fitment. I am working with the Discount tire in Concord, NC (Justin) on identifying the potential final choice.
Originally posted by moregrip
unsure, how did you find out 245/40-19's would fit?
that would be sweet to be able to run a 40series profile on a 19"
rim!
rim!
todd says 245/35/19 will work, thus i was wondering if a 245/40/19 will as well? i think it may work, but we'll see
Originally posted by blufox
does 20x8.5 245/40-20 work in an 04 TL
So for now it looks like 19" is as big as we can go with stock height.
What is the WIDEST size rim I can go with without running into any problems?
I was hoping like 19x8.5 in the front, and 19x9 in the back
235/35/19 in the front and rear (or maybe even 245/35/19 in the rear)
Once some kind of coilover suspension comes out, i'm going to set them pretty low, to completely eliminate ANY wheel gap. So i need to keep that in mind, that the car will be sitting pretty low, and I dont want any rubbing problems..
So will my setup work?
And i'm going to be getting a 6speed, so what offset should I get to clear the brembo caliper? I want the deepest possible lip.
Thanks!
Thanks!
The 245's fit perfectly. I had to go with the 245 on the 8.5" b/c the 235's were causing the rim to stick out too far from the tire.
