'04 TL with G37s wheels & tires, sizes.
Old 02-22-2010, 07:29 AM
Acura TL 04, G37s 19"
eduardmc's Avatar
i have posted before about my 04 tl with infiniti 19" wheels and tire. i bought the car from a private seller with them installed already. the wheels and tires are all OEM from the g37s. here is the problem (if it is one)
The g37s setup with the tire sizes are
FRONT 225/45R/19
REAR 245/40R/19
this is the same setup size for my car (front & rear).
should i change anything
Get new tires matching the same size (i'm planning on buying new tires in the summer anyway)
or change the rear to front & front to rears?
i'm a total noob about wheels and tires this is why i'm here asking for your help.
thank you all
Old 02-22-2010, 08:01 AM
Turbonut's Avatar
I believe those specs on the G37 sport:
Front 8.5 +43mm
Rear 9 +45mm
Leave them as is. The rears actually split evenly when compared to the 8" +45 TL wheels, and the fronts are only off by 2 mm compared to the TL centerline.
The only problem is the tire size which is leaning more to a RWD vehicle. When replacing the tires I would suggest sticking with a 245/35-19 all around to keep more closely to the 25.7" diameter as the G37 tires are about 1" taller.
Maybe someone else will have some other ideas.
Old 02-22-2010, 08:13 AM
CLtotheTL32's Avatar
Received 9,524 Likes on 6,180 Posts
I would keep the 225 and 245 widths for the front and back, but change the tirewall to a 35 series. The thicker the sidewall, the more you throw off your speedo. It's not a huge amount, but more than you would want.
Old 02-22-2010, 08:48 AM
eduardmc's Avatar
so next time order 225/35 245/35 19" . any recomendation on the tires i can buy, good peformance all around with a smooth ride feel, very little noise. the oem g37 brand are bridgestone potenza RE050A
Old 02-22-2010, 05:34 PM
^That's what I would recommend doing. For tires, I opted to get a set of All-Season tires with a good treadlife warranty. I got a set of Kuhmo Ecsta Platinum which come with a 60,000 mile warranty. If you are looking for more of a performance tire, I can't help you too much there, but I'm very happy with the Kuhmos.
Old 02-22-2010, 07:05 PM
Turbonut's Avatar
Why would anyone install a 225 on the front of the TL when the minimum width should be 235, and especially since it's a FWD vehicle with almost 70% of the weight on the front wheels/tires? Maybe someone could explain the thought process.
Also with the 225/35 and the 245/35, the rear tires will be over 1/2" taller, and that in itself would look rediculous.
Rethink the decision.
Old 07-02-2010, 07:40 PM
Will they clear Brembos?
integra92red's Avatar
Bumping this up for I have a set of these on the way and am in the market for tires.
I'm thinking 235/35's all around would be good, unless I should get a 245 for the 9's?
Also stupid a question as it may be, I wonder if I put the 9's in the front? Performance/common sense wise I would say so, but aesthetically I'm not sure...
Insight?
Old 07-02-2010, 08:48 PM
Carfreak
carfreak55's Avatar
Match all sizes of the tires for all four tires on the car. Staggered tires are only meant for RWD.. not FWD. It's inefficient for your current setup..
Old 07-03-2010, 02:31 PM
Spinnin them beats
Acuraluvr's Avatar
agreed. go 245/35/19s all around. i have falken fk452s all around in that size on a 8in wide wheel, youll be good. For price, these are good tires. however, wear wise, id suggest getting an all season as well.
Old 07-03-2010, 06:13 PM
Stop Drop and Roll
jtsangAZ's Avatar
will you post some pics of your ride with the g37 wheels?
Old 07-03-2010, 10:22 PM
245's sound good to me. I think the 235's wold look stretched anyways, something I would like to avoid.
Yes I'll post all sorts of pics, I'm getting antsy, I saw a G37 tonight when I got out of work, very exciting (shut up, not many of them around here ) I hope to have them on in a two - three weeks.
I have to play around with what I need for spacer over the Brembo's, from what I read it looks like 10mm, I like to get way with 5mm if I can, if not, go with the bolt on Ichiba 15's.
Old 07-06-2010, 11:48 PM
LowNslo TypeS's Avatar
i used a 245/35/19 tire on my g37s all the way around...i used a 5mm spacer and they cleared 10 will get u pretty flush...
Old 07-07-2010, 08:59 AM
Awesome, excellent news!
Which wheel did you put on the front, the 8.5 or the 9?
Old 07-08-2010, 11:14 PM
2QAYL's Avatar
sweet!
Old 07-10-2010, 12:33 AM
the 8.5... with a 5mm spacer... even with the rears it didnt clear my stock calipers.
Old 07-25-2010, 07:55 PM
The wheels are here, I'm ordering the hub centric rings and 5mm spacers tonight ,then getting the wheels put on a week from today and I'll take pictures of it at stock height, lowering is hopefully within a few weeks.
Old 07-25-2010, 07:57 PM
LowNslo, I looked through your threads, all I can see are the G35's and the Maxima wheels, do you have pics of your car with G37's?
Old 07-27-2010, 02:00 PM
Are you folks using stock lug nuts with all of these Nissan/Infiniti these wheels?
I was looking at these:
http://www.amazon.com/McGard-84537-C...tive&carId=001
However is says for aftermarket wheels only, but I would think my G37's don't really qualify as aftermarket...
Any insight?
I do have 64.1 - 66.1 hub centric rings and a set of 5mm and 3mm spacers coming to mess around with, so 'wheel' see HAHAHAHAHAHA
Old 07-27-2010, 03:29 PM
Ek_Mark97's Avatar
do you have to check on ur lug nuts every so often i had a set of these on my tl and the rear would losen up by them selves i sold those babies in a hurry
Old 08-01-2010, 08:27 PM
Had the tires installed today, went with 235/35 -19 for the front and 245/35 - 19 for the rear. Tried to install them but stock lug nuts will not work. I need lug centric nuts which I ordered today from Advance for $21.xx with tax.
The 3mm are soooooo close to clearing, if you were to either grind away a little bit from the caliper or the inside of the wheel they would work. The wheels will actually spin with them but they scuff up the caliper.
So with the special nuts and 5mm spacers, i think this is the ideal setup for these. I'll get good pics, they're gonna look siiiiiick!
Old 08-04-2010, 09:41 PM
Definitely needs a drop now, not sure what, but it needs it.
Here's what you need, tires are just suggested sizes, whatever brand, do what you want:
(2) 245/35 - 19 Nankang NSII - Rear
(2) 235/35 - 19 Nankang NSII - Front
(2) 5mm 'Akata' (ebay brand) 5x114.3/64.1 Bore spacers - Front
(2) 3mm 'Akata' 5x114.3/64.1 Bore spacers - Rear
(20) Mr. Lugnut 'Lug Centric' Nuts, 13/16" Drive M12 x 1.50, Special order from Advance, *Will edit with part number later
I think that's it, I have hub centric rings, haven't used them yet, rides quite good.
Old 08-05-2010, 10:24 PM
HaRDbODyTL's Avatar
thats guna look sick with da drop
Old 08-06-2010, 08:07 AM
-------Tim-------
Slpr04UA6's Avatar
Looks great!! I agree, once you lower it a little it will look even better than it already does. Did you happen to weigh the wheels prior to install? Just curious as to how much they weigh.
Old 08-06-2010, 10:26 AM
Thanks guys, I did not weigh them, but I'm going to have the curbage repaired so I will weigh them up, they are hefty though.
Lug nut part number is 'Mr. LUGNUT 5195-4' for a bag of 4 nuts, 5 bags required, because you didn't know that you car has 20 nuts :P
Old 08-08-2010, 09:41 PM
'04ack's Avatar
Looks great man, could you use the 5mm spacers both front and rear? Also could you use the same size tires front and rear? I'd like to do this fo rmy car, those are actually the only rims my wife and I agree on.
Old 08-08-2010, 09:43 PM
'04ack's Avatar
Btw, can you run these wheels without the spacers? Sorry for all the questions.
Old 08-08-2010, 10:02 PM
You need 5mm spacers in the front if you have a 6MT. I guess you could use some 5mm spacers in the back, I'm going to put the 3mm ones back there some time.
Looks pretty flush as is.
I would use the 245/35's the people before have mentioned all around. If I was to redo it I would put 245 35 on the front and 255 35 on the back.
Old 08-09-2010, 09:56 PM
'04ack's Avatar
Thanks, for the info.
Old 08-09-2010, 10:07 PM
eduardmc's Avatar
i have no spacers with them and they fit fine. Also i need new tires what would you guys recommend
Old 08-09-2010, 10:27 PM
eduardmc's Avatar
why would you do 245 35/ 255 35. didn't you like you set up? i have to buy new tires with for my g37 wheels. please let me know
Old 08-10-2010, 05:30 PM
This is correct. Autos which lack big ol' brembos don't have the spacing issue.
Old 08-13-2010, 11:29 PM
8th Gear
330iZHP's Avatar
please drop that car - it looks like a truck right now...the wheels look good btw
Old 08-14-2010, 08:16 AM
Thanks, yeah it does need a drop bad, I can't decide which route to choose, coilovers or shocks, but I'm taking them off next week after Honda Day, probably going to sell them anyways. Like I said before I LOVE how they look, but too heavy for my taste.
Now that I'm used to them, I'll get a feel for how much power I lost when the stockers go back on.
Old 08-14-2010, 08:32 AM
8th Gear
330iZHP's Avatar
I know what you mean. When I took off the oem 18s and heavy Bridgestones on my 330 and installed Fikse Profil 10s (19x9=17lbs and 19x10=19lbs) I could feel a difference
Old 08-15-2010, 08:18 PM
eduardmc's Avatar
i installed the new tires now. When with 245 35 19 nankang ns II. The drop look awesome with the H&R sport spring. by the way this tire are much better than the bridgestone potenza i was driving with the g37 rims.
Old 08-15-2010, 08:32 PM
Cool, my on ecomplaint about the tires is they can be loud at times, but it doesn't bother me. The grip good for a chinese tire.
Old 08-15-2010, 09:35 PM
eduardmc's Avatar
before, the drop looked weird having 225 45 19 front and 245 40 19 rear (h&R sport spring). i hated the look because those tires were from the origina oem g37s and had a weird size. now after doing this i cannot believe i did not do this before. the drop is nicee. it look lower in the front than in the back, because of the design of the body. i'll still install the koni sp3 and do a lilttle lowerrr.
Old 08-17-2010, 07:00 PM
eduardmc's Avatar
here is my tl 04 converted (mostly) to type s
is running on stock shock with H&R sport sprint. The drop is mostly perfect for street driving. i would really like to install the koni yellow to drop 1/2" more but new york streets are to harsh. i might install it next summer if i still have the car.
I hated the drop while running stock g37s tires. now that i replace the tires with a all-around 245-35-19.
Old 08-17-2010, 08:16 PM
Oooooo... It does look good with a drop.
Old 12-11-2010, 04:50 PM
Ty2a04TL's Avatar
Hey Guys,
Looking through all these threads I picked up a set of wheels and was wondering what type of lug nuts you guys used to mount G37 wheels to the 3G. It looks like it takes a 12x1.5 Mag style Lug, with 21mm width shank. I have been looking everywhere but no luck. Just wondering what you guys used???
Quick Reply: '04 TL with G37s wheels & tires, sizes.
