Yellow fogs or bright white fogs?
Old 11-09-2015, 01:40 AM
9th Gear
fwjoe817's Avatar
im torn apart i want to do the yellow fogs and i want to the bright white fogs. is there anyone running these i would like to see some pics
Old 11-09-2015, 08:27 AM
sterlingvq's Avatar
i'm running piaa plasma ion's so, pretty yellow. fantastic output. i dont have a pic handy tho
Old 11-09-2015, 09:16 AM
Be a better driver
RedRyder's Avatar
^same, also really helps in rain. But I would only use them when you actually need them or they may not last as long. But they do a great job in my experience. Only downside is that for some inexplicable reason they have become more expensive...I used to buy them on Amazon or Ebay for around $40/pair, now they are almost twice that.
I buy 13556 H3's though, so the price may differ for you. Unfortunately I don't have a photo handy either.
EDIT: Found a couple really old photos, but they're not at night so you can't get an idea of the output. Shows the color though I guess if that helps you, 6k HID low beams with the PIAA plasma ion yellow foglights.
Old 11-09-2015, 10:26 AM
Received 8,711 Likes on 6,718 Posts
it's all personal preference.
Old 11-09-2015, 12:48 PM
sterlingvq's Avatar
Found a pic...
Old 11-09-2015, 02:31 PM
Jeff
Oh Sickest TL's Avatar
Old 11-09-2015, 04:56 PM
Life Connoisseur
MonkeyTrucker's Avatar
3,000k HIDs for fog lights. I chose these for visibility (usable light) and with the independent fog light mod, I often use these solely in areas where light is reflected back into my eyes.
It's all about usable light, the "brighter" lights aren't helping you out with more visible (usable) light, and you usually wind up causing yourself to squint from the light reflecting back onto yourself. Anything over 4,200k-4,500k is overkill for all eyes on the road.
Was looking for a specific graph that combines all these below, these will have to do. Hint understand kelvins AND lumens correlation to visible/usable light.
Oh Sickest TL (11-09-2015)
Old 11-09-2015, 07:55 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
White
Old 11-11-2015, 02:54 AM
Boosejars's Avatar
i'm running LED Fog light bulbs, with Yellow Vinyl Overlays, if i get tired of the yellow I can just remove the vinyl, work for me
Old 11-11-2015, 07:43 AM
vietxquangstah's Avatar
I read a article somewhere explaining that yellow fog lights doesn't actually help cut through fog like most people think.
I prefer white fog lights
Old 11-11-2015, 07:55 AM
2014 RDX AWD Tech
Comfy's Avatar
I realized it recently (from a lighting expert) that color has nothing to do with fog lights. The beam and direction defines a fog light. You can choose whatever color you like. Fog lights are to be used only in poor visibility conditions and the main purpose is to see the edge of road while moving very slowly. Good luck.
Old 11-11-2015, 11:19 AM
Life Connoisseur
I think that people with yellow fogs think that they're not blinded by the reflection of the light back in their eyes
No light "cuts" through fog
cruisingnycfl (11-28-2015)
Old 11-11-2015, 11:32 AM
Life Connoisseur
You need to understand the relationship of kelvins (color) to lumens (brightness), did your expert explain that to you, if not here you go:
HID Bulb Colors & Kelvin Temperatures | HeadlightRetrofits.com
Basically, you get into ridiculous colors (blue --> purple), your usable light (lumens) is decreased.
It's simple really and visualized in the graphs I've already provided.
Again, the peak HID Kelvin (color) for light output is around 4300K.
You run anything above that, your decreasing your usable light. Period.
Again, I choose yellow, because there's less lumens bouncing/glaring back into my eyes. Go with white, you'll have a brighter light reflecting back into your eyes when you actually use them in the fog or in areas where there are high reflections.
For those that still don't get Kelvins, in the simplest terms, you'd have more usable/visible light with 1000k bulbs than 5000k+ bulbs. Kelvins = Color
If you want your fog lights to actually serve a purpose, stay within that Kelvin (color) range.
Old 11-11-2015, 11:50 AM
Life Connoisseur
The graph above makes more "sense" when you visualize these lines:
Color DOES matter if you want them to function as fog lights when you need them, if you want to be obnoxious and blind yourself and others, go with bulbs 5000k+.
Old 11-11-2015, 11:55 AM
maxxyboy97's Avatar
Hey guys I was in my 2004 Acura TL and I noticed that I had two sets of fog lights, can anyone explain to me what they all mean?
Old 11-11-2015, 12:04 PM
Life Connoisseur
The fogs in the headlight housing functioned fine in 04-06 TLs, previous owner installed second set in lower bumper to look like 07-08 TLs.
The fogs in the headlight housing function no less than those installed in the lower bumper.
Old 11-11-2015, 07:01 PM
9th Gear
fwjoe817's Avatar
thanks for all the info guys, went a purchased some yellow fog light bulbs for my fog lights. i will post pictures later on tonight
Old 11-11-2015, 07:10 PM
Life Connoisseur
I'm sure they will look GREAT, and easy on your eyes, it's a win/win.
Old 11-12-2015, 11:14 PM
9th Gear
fwjoe817's Avatar
i didn't have time to post any pictures yet, for sure i will tonight i just fix the passenger side motor mount was getting this clunk noise since i was doing that i decide to put them in. like i said im going to take some pictures, im take a drive to downtown Dallas and take a few pictures
Old 11-14-2015, 09:57 AM
mazen222's Avatar
White.
I find yellow fogs are nicer on white cars only, otherwise 6000k white is my personal preference.
Oh Sickest TL (11-14-2015)
iiamchili
11-16-2015 05:01 PM
Keazo M Thomas
11-14-2015 07:22 PM
TBO
11-12-2015 05:16 AM
iiamchili
11-03-2015 10:26 PM
Quick Reply: Yellow fogs or bright white fogs?
