WTF is Seafoam!?!?!?!?!?!?1
Registered VTEC junkie
Basically an engine/fuel system cleaner for most engines.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
Originally Posted by IlovemyAcura
Oh i see
is it worth buying?
is it worth buying?
haha, this sounds like rehab
"ive been hooked on this for 6 years, cant live without!"
and goldenboy don, that was not directed to you just so you know, just 6 years was an easy number
'06 750Li Sapphire/Creme
It's been used in the marine industry for YEARS but is MOSTLY related to winter conditioning of the engines (shutting down for the season or starting back up for the nex season). It basically removes carbon build up. IMHO using it on a car that you use everyday that is fairly new is a waste. These cars are ALREADY designed to be FAR more efficient than older cars. Now, if your car is three of four years old and you want to clean it out, run some through the gas tank as outlined in this forum....once (every two years or so).
All you have to do is remove the air intake snout to your TL
Look at the butterfly plate- its covered in crud. Now still think seafoam or some kind of cleaner is not needed??- then why do newer cars come with a port specifically to attach some sort of cleaning system!!
Anyone who understands engines knows they are huge crud factories of unburned gas and hydrocarbons- oil residue etc. That stuff gets right back in the intake and pistons, valves etc, and it clogs the engine oil passages too.
Anyone who says its just for storing engines has no idea of the many uses, in boats cars mowers- watercraft-jetskis and more...so probab;y not a current or ever user of the stuff!
The azinr threads have a lot of good info and practical experience from memebers on acuras of every model
Anyone who says its just for storing engines has no idea of the many uses, in boats cars mowers- watercraft-jetskis and more...so probab;y not a current or ever user of the stuff! The azinr threads have a lot of good info and practical experience from members on Acuras of every model
Oh i see
is it worth buying?
is it worth buying?
It makes a big differance if you have over 50k miles- that for sure
Will it help overall at 15k on a new car- not as much, but prevention is the key to
better mileage and healthier engines.
There are other products that do similar things- if one of us buys the 50 honda kit- that may be the new rage- but for now,,,,
after looking inside the Edelbrock intake of my truck- and my 01TL TB plate, I decided it was worth doing. Both appreciated it, and a spray of the TB plate now and then helps.
Great pic on another thread of TB crud buildup- the cranckacase breather tube goes direct to the intake port!
Originally Posted by KSuchdeve
How come one of these threads pop up every few days? Do people not know how to read?
acuratl26
04-23-2020 07:30 PM
ahsm
09-09-2015 08:35 AM
