Probleme
Probleme
Jai une acura tl 2006.... jai courser et kand le char a kick down jai mis le gaz a fond sa donner un petit coup dans tranny....2 jour plus tard kand ma voiture etais froide il a bien rouler des kil tomber chaud il embraye pu aucune vitesse.... le check ingine a allumer sa ma sorti le code p0741... jai changer tout les soleniod...c ecrit convertisseur de couple,embrayage circuit du soleniod rendement ou bloquer en position desenclencher
From Google Translate:
I have a acura tl 2006 .... i run and kand the tank kick down i put the gas thoroughly give it a little kick in tranny .... 2 day later kand my car was cold it rolled well kil to fall warm it clutch pu no speed .... the ingine check to turn on its my out the code p0741 ... I changed all the soleniod ... it writes converter of torque, clutch circuit of soleniod yield or lock in position to switch off
Sounds like your transmission is dead
