New aftermarket headlights? [pics]
#121
Factory adjustment hole, passenger:
Getting closer:
There you are!
#122
Oh man, that would have saved me quite of bit of pain hahah. Ugh well now I know at least. Any luck looking up that harness for LEDs? Would love to give them a shot
#123
Are you guys running LED rear turn signals in conjunction with these headlights? My worry is that these will cause hyper flash since my rear signals are LED (currently running incandescent fronts). I have the error free LED signals in the rear so I hope the upgraded front turn signals won't trick the car into thinking a bulb is out since in theory these will draw much less energy?
#124
Null and proud of it
From what I understand, they are LED and have a resistor bult in to prevent hyper flashing. It looks like this kit is Plun N' Play!
#125
#126
Here's the amber kit that I pulled out of the front yesterday that I'll have for sale when I get around to posting them up
#127
If you want to use the LEDs as DRL, I suggest wiring it to the DRL ststem. Or you could get a DRL module (hooks to battery and ground/uses alternator voltage jump in battery to activate) and find the LED power wire on the pinout, I suppose.
IDK, I was hoping it could work this way... Only thing, the LEDs will not be bright enough to use as DRL, really.
Tried it before and the LEDs need to be extremely bright to be seen in direct sunlight like OEM DRL is.
Partial sun:
Full sun:
These LEDs are BRIGHT, I'd say at least as bright as any OEM in the full sun in my limited experience.
#129
https://store.ijdmtoy.com/LED-Daytim...ecoder.htm#top
It looks like the one I have.
If all else fails, just wire the DRL bulbs to an ignition-switched 12v source. Your DRL bulbs will be on day or night (but they look real good alongside the new headlight accent LEDs).
You'd still have the DRL code in the cluster but you would have functioning DRLs again
#131
Try using these with the "R3" option
I also have the same R3 harness and am wondering what temperature the DRL bulbs are that come with the new headlightz? You say they match the LED accents nicely, your talking about the bulbs that come installed in the headlights right?
I'll be uploading some pics soon
#132
Oh no, I meant that my LED bulbs "match" nicely in the sense that even though mine are amber but the whole "LED look" just is just so modern and fresh IMO.
The new headlights came with a regular halogen bulb so I wouldn't recommend using that since it looks old school.
Awesome you got yours! Looking forward to your pics man!
#133
Bear with me....im uploading from mobile....
So overall, the install was fairly straight forward. The company does a good job providing a sheet of instructions and they are simple and clear. This was the first time I've ever removed the front bumper on any vehicle, and this is my second TL. By far, removing the bumper and headlights is the most difficult part. However, now that I've done it once. I'm confident, I can get it off within 30 minutes. Was just alot of trial and error, putting it back on as well. The bloody headlights have about 7 bolts holding them in place, 2 of which are on a clamp which is an absolute PITA to get too.
Aiming the lights were a bit tricky as well, just tedious really. If anyone does take the plunge and orders these sets ...make sure you seat the HID bulb correctly. Be careful to pay attention to how your bulb is seated in your original headlights.
Enough rambling..onto some shitty install pics
Last time she will be stock
superb packaging by AKG, really well done.
Didn't get a shot with the lights and fogs together. Will try and get some tonight
#136
I'll think on the wrap lol. Right now, I really enjoy the subtle bits of chrome on the car.....so if I get bored of that, I definitely change it up
Thanks for being the one to post these man. I get compliments everywhere I go, and I was able to give the front end a more aggressive styling.
I may have to remove the front plate, but its a pricey ticket if I get pulled over
#137
#140
Got a few more pics of the headlights. This time with them actually on lol.
I'll be updating my thread with a few more...
#145
#146
I just did a bit of rewiring on the headlights in order to have the DRLs always on and an added bonus, I also got around the DRL warning light on the dash!
I used some spare short wiring harnesses I had to tie the LED bulbs together. I also tied them together using the existing long wire harness (posted above) to run from the passenger side to the driver side.
Once the were both wired together, I ran the ground wire to ground and ran power to an ignition-switched point on the fan relay in the fuse box pictured here:
I was able to get around the DRL warning light because I had a pair of resistors from VLEDs I had previously purchased (didn't work with the LEDs directly due to flicker)
In this case, I was able to plug the resistors into the stock blue connector it made the car happy.
These were the "R2" resistors I used:
Here's a quick 'n dirty pic of the car tonight with the low beams on with the DRLs:
Success! Hey Hamburglar give something like this a shot!
mhtut83 (01-01-2019)
#147
Nice job on wiring the DRLs to run by themselves. I'm hoping someone does a write up for independent fog lights for our 07-08s. If that happens, then I'll run DRLs to match the LEDs and fogs to complete the look
#148
#149
I would think that if you wanted to trigger the fogs to turn on with just the parking lights it would be easy to tie the fog power wire to any of the lights that turn on with the parking lights. Such as the fender side marker lights or the parking LEDs on your new headlights.
#150
Are you looking to have the fogs on with the low beams off?
#152
Hmmm I'll ask a buddy who's good with electronics and see if this would be a smart route to take. Basically I want to run the fogs independent as it's been done for 04-06 models. But if it's not possible for 07-08 models, I'd be happy with being able to run the fogs with the parking lights
If anybody wants to use led drl on 07 and 08 models, but don't feel like paying much look up my thread. Some wire and two high value resistors is all you need.
#153
peter6 (01-03-2019)
#154
#155
#158
#159
So as an update on my DRL situation, I ordered some resistors and using them, the DRL warning light is now gone, but for some reason the lights still don't turn on. Gonna try and buy some new lights, that's the only point of failure I can think of at this point lol
#160
^^That's interesting. I tried plugging the DRL bulbs in to the stock sockets when I was installing the new headlights and I couldn't get them to work either......
the bulbs look fine, I wonder if I missed something (I did check both sides to ensure polarity wasn't the cause).
even though, I really like the headlight look without the DRLS on. I think it compliments the headlights especially when paired with the NBP.
I would only consider putting LED bulbs in for DRLs in order to match the rest of the headlight.
