Gottem: 2006 TL 94K One Owner Navi $7700
Yes I finally bought another TL ( bought it almost 2 weeks ago)
This is an 06 Anthracite with navi.
One owner and one accident (hit a deer).
What should I look out for or do?
I did an oil change and got it inspected. I'm going to change the trans fluid too. The car drives very nice and transmission actually shifts amazing I can't even tell when it's switching gears.
Acura TL - Album on Imgur
Photo album of the car.
Let me know what you guys think
iWhine S/C 6MT TL
Congrats.
You went down this path several times with purchasing a used car and asking others here for advice.
If in doubt with what might or might not need attention, pay for a certified technician or a dealership to do a multi-point inspection and tell you what's going on.
2nd option would be to search here since these type of threads are constantly made about either "Looking to buy a TL, what to look for?" or "Bought a TL, what to look for?"
Best of luck.
Best of luck.
I bought an '06 with 77k two weeks ago. Here's all I've done
-3rd/4th pressure switch and drain/fill with DW1. My trans was shifting fine, but this was for peace of mind. Honda trans are fragile, can't hurt
-Oil Change & new air/cabin filters. The air filter was clogged!
-Checked all motor mounts.
-My car already had the timing belt/water pump/tensioner/spark plugs done, but yours is due (if not done already). I believe the interval is 105k/7years.
-And like with all my pre-owned purchases, a very through interior detail.
Also tinted the windows and added felt to the window strips. Can't stand clear windows
lmao.
Btw if you don't mind me asking how much did you pay for your car?
Congrats.
Best of luck.
Best of luck.
Received 6,470 Likes
Yung, please use the Multi-Quote button. It's the middle icon in the lower right hand corner of each post. Your reply will look like the one above! ^^^^^
Ok guys so I just noticed this weird thing when I started it up in the morning.
Basically right after starting I put it in Reverse and it made loud "THUD" noise not clunking or grinding. I tried to re create the noise but it would not do it.
I am changing the tranny fluid now.
Will update...
Will update...
The clunk huh?? I get the clunk sound whenever I'm parked on an incline.
Sounds normal to me.
Unless you're talking about the sound it makes when it shifting it to reverse.
Either way, it sounds normal to me.
Yup had a friend explain it and he said it's normal because the car has to unstuck the gear and go into reverse which is that sound.
It's not a clunk noise. It sounds like really heavy bass drop. Sorry that's the best I can explain lol
lanechanger
10-13-2015 10:56 AM
us285126
10-02-2015 02:03 PM
