Drive by wire location
It's on the passenger side firewall. Very easy to replace. Usually a search for "APP sensor replacement" or something similar will find the info.
Try this...https://acurazine.com/forums/3g-tl-p...sensor-730958/
I "think" the ECM is inside near in the front/lower part of the center console. Do not quote me on that...have never needed to go looking for it so basing that response off of things I have read on here.
Maybe providing a little more details about the issue at hand would help others point you in the right direction.
Define "the car is going no where" since this first sentence sounds like transmission slipping issues. However your further descriptions seem to describe it is just slow, not that it revs but goes nowhere. If the engine RPMs are increasing without an increase in speed, the transmission is slipping.
A pause/lag at 4k sounds like a VTEC issue....others will need to chime in here. I know there have been other threads with similar complaints at the 4k mark, but I don't remember the details of what the suggested fix was other than check your oil.
have you checked to make sure it's not just a bad battery or loose battery terminal?
I have a new battery but it's 600 cca. I heard some guys saying 750 cca is better. I do have a subwoofer but There was a time I disconnected it when I got my new battery but the car was good for a couple hours.
prosun
04-11-2017 06:20 PM
triax37
04-06-2017 09:57 PM
