Do you need to replace Xenon headlights?
I'm rather clueless when it comes to them. I love the light they give, but I was curious if you need to ever replace them (I assume you do) and what the cost is.
Joe
Joe
HID's should last a long time but not the lifetime of the car. they have a 3000 hour expected lifetime on the bulbs. so depending on how much you use them it will not need replacing anytime soon. if you drive 10 hours a week using your lights(this is alot of night time driving or just leaving yur headlights on all the time) that comes out to 520 hours of use. this comes out to almost 6 years before it needs to be replaced. most people do not use 10 hours of headlights in a week but you get the point.
Does flashing your headlights, or turning the lights on and off a lot, shorten the life expectancy of the bulbs? Since I found out how much it costs to replace the bulb, and the fact that you have to remove the bumper to do it, I am being more careful with my use of the headlights.
A typical halogen bulb found in most cars will last 250-300 hours before burning out.
So our HID's should last almost 10X longer. Of course, I'm sure a bunch of other factors could make that an optimistic estimate but like caball88 said, you get the point.
However, I'm not sure why you would want to flash your lights given that our high beams are also HID. Ever notice our how HID's aren't instant on but rather they fade in to full power over the span of a few seconds?
If you flash someone, all they'll probably see is a dim blue glow.
Acura said:
"These bi-function HID high/low beams are made possible by a shutter device that mechanically controls the light output of the HID unit. When the driver selects high beam, an electric solenoid in the headlight moves a shutter forward, opening up a greater reflector area inside the headlight. When the lights are operated on low beam, this shutter repositions to act as a cut-off to keep the lighted area closer to the vehicle."
Originally Posted by rets
The difference btwn Highbeam and lowbeam is the "shutter" (OFF or ON). The switch between high and low should not shorten the life of HID.
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
