DIY Video: Uninstalling OEM Intake & Installing Cold Air Intake 3G Garage #B-001
#121
AZ Community Team
Received 7,770 Likes
No, it won't void warranty UNLESS the failure is directly attributable to the modification. For example, a CAI has no effect on, say, ABS modulator failure, so the warranty for the ABS part should be intact. This is the crux of the Magnusson-Moss Act.
Yes, in the sense that the dealer MAY either outright lie to you or find some cockamamie connection between your CAI and whatever fails to deny your warranty claim. Depends on the dealer.
#122
Excellent.. just did my AEM CAI. My vibration mount was in a different spot though. it was inside the engine bay as opposed to where the grounds are. Aside from that everything else was the same.. oh.. and don't forget to unclip your fogs before you go yanking on your bumper too much... lol
#123
#124
well... it helps to make it easier to get it down there... Don't think it's absolutely necessary, but I'm sure it's just easier. Plus taking the bumper off is literally 15 mins. It's really up to you. I took it off thinking I was going to have to do that.
#127
Just take off the bumper. It only takes 20 minutes (tops) and gives you all the clearance you need to do whatever you want to do. The OEM intake tract can be a pain in the ass to get out---even moreso without removing the bumper.
#128
CEL Light
I know old thread. Just installed aem v2 and engine light came on. Is this normal or did I mess up the tubing for the coolant? someone please chime in. tks jp
#130
AZ Community Team
It's not uncommon to get a CEL after install. The way to avoid it is to remove the NEG battery terminal before starting the install.
It should go away after something like 20 miles or 30 minutes of driving - long enough to make you wonder, but not too long.
Can't really tell what's going on in your picture. Which line are you concerned about exactly? Can you show a slightly wider view along with the close in view?
#131
Bearcat,
Tks for replying. I just want to make sure that the coolant goes to these two lines. Im glad that other people have gotten CEL's before. I didn't unplug my battery until halfway through when I realized that the aem v2 would not fit through the hole unless the removal of the battery.
#132
AZ Community Team
Looks like the Throttle Body coolant line?
You're in SoCal, right? If so, you should do this: Throttle Body Coolant Bypass (link).
#134
AZ Community Team
I can't tell from the pics. Look at the pics in the linked thread for the inlet and outlet ports on the TB. If that's where you're connected, you should be good.
#135
I looked at all the threads and saw where the tb bypass was unplugged and where it was rerouted too. I have my tb going to the rerouted so i just want to make sure i didnt put coolant somewhere its not suppose to be.
#141
Fixed links, thank you for bringing it to our attention.
