Best LED's on the Market! Who Needs HID's?!
Old 10-05-2014, 06:28 PM
  #361
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Lol, what a dumb question i asked.
My interior leds flicker during startup also.
Only during the cranking process.
Old 10-06-2014, 09:19 AM
  #362
thegipper's Avatar
[QUOTE=Frosty;15185568]I think the seller may have a solution to the radio interference for those that are experiencing it. As I've stated before, I have no interference whatsoever, even with all 4 of my LEDs running, so this issue is definitely not universal. I'll share the details of the solution once I know more.
Frosty,
Has the seller figured out a way to block the radio interference yet?
Thanks for keeping on this!
Old 10-06-2014, 10:55 AM
  #363
ddaviglus's Avatar
Just bought some 30w h11 Cree led's. Ill follow up with the results
Old 10-08-2014, 03:13 PM
  #364
I had a very difficult time installing these.
I even removed my battery to have more room to stick my head in and see what is going on.
Upon inspection, I saw that the bulb was installed, with each tab in place under the 3 screws.
However, I was able to wiggle the bulb around, very easily.
I tightened the 3 screws down as much as I could, and it's still very loose.
For now, I wrapped the base of the LED bulb with duct tape.
Makes the fit much tighter, with no more wiggle.
Probably not a good idea considering how hot these bulbs get.
On the bright side, they looked good when testing them out, and brighter than what I had before.
I'm now just worried that the headlight is not sealed, and moisture will get in.
I also noticed that the alignment tabs are not the same for each headlight.
Can someone confirm? Even, does anyone have a picture of what the headlights look like from the back so I can see the mounting screw positions?
I'm VERY close to taking off my bumper and removing my headlights to just install these bulbs properly. Not that happy about it, I must say.
Old 10-08-2014, 03:34 PM
  #365
Comparison with my old JLC 35W Cree
Old 10-08-2014, 06:23 PM
  #366
under renovations....
CubanLynx84's Avatar
GP, mine are installed with the stem I'll say on an angle. The top led is pointed in an upward and the bottom one down and outward. I don't have a pic of them. I did notice the wiggle and I'm watching the reflection as I drive to see if they do move so far nothing.
Old 10-09-2014, 09:22 PM
  #367
Frosty's Avatar
Can someone confirm? Even, does anyone have a picture of what the headlights look like from the back so I can see the mounting screw positions.
It has been over 2 months since I installed these, and I have no moisture inside of my headlights. You should be fine.
Also, now that you mention it, I do think I remember the alignment tabs on the back of the headlight for my fog bulbs (your DRLs) being different. This is why I'm sticking to my notion that the housing itself is primarily to blame for the slight wiggle that is present with these lights, as there was no wiggle present in any of the other locations I installed them (including my Inspire fogs).
Pics look good! Thanks for sharing.
Old 10-10-2014, 07:15 AM
  #368
thegipper's Avatar
Any new information about the FM disturbance from these lights frosty? Did the seller come up with a fix yet?
Old 10-10-2014, 02:17 PM
  #369
MyGuti's Avatar
I just got these today. I put them in both sides and turned my car on before I screwed them into the housing to check if they work. They don't turn on. And inside on my dash, I get the DRL notification. Someone plz help!!!
Old 10-10-2014, 02:20 PM
  #370
Frosty's Avatar
Will let you know ASAP. Still waiting to hear more details from seller.
Reverse the plug connector that pairs the OEM wiring to the LED and try again. LEDs are polar, so there is only 1 right way.
Old 10-10-2014, 02:33 PM
  #371
MyGuti's Avatar
I changed the plug that connects from the LED to the wiring connected to car, just turned it upside down, even though the wiring diagram said to do it the way I had it before. The DRL sign went away in my dash, but lights don't turn on....
Old 10-10-2014, 02:44 PM
  #372
Frosty's Avatar
Check to see if your E-Brake is engaged.
Old 10-10-2014, 02:53 PM
  #373
MyGuti's Avatar
its not
Old 10-10-2014, 03:45 PM
  #374
MyGuti's Avatar
If I put my old, stock DRLS back in, and they turn on, what do you think could be the problem as to why the LED's arent working?
Old 10-10-2014, 03:57 PM
  #375
Are you running it with a harness? If not, I would get a harness.
Old 10-10-2014, 07:34 PM
  #376
You need the vleds harness to provide full power to both leds.
Old 10-10-2014, 07:43 PM
  #377
MyGuti's Avatar
Link?
Old 10-10-2014, 08:00 PM
  #378
Its a few pages back. The harness is $50
Old 10-10-2014, 08:29 PM
  #379
Frosty's Avatar
Forgot to reply to this:
Originally Posted by mzilvar
Do these ones come with a driver?
The Black Edition and JDM Edition both come with a driver. The Blue Edition does not.
Old 10-10-2014, 09:48 PM
  #380
MyGuti's Avatar
One side only
Update: I got the lights to turn on! Only thing is they will not turn on unless one side has the original factory bulb in. So both leds can't be plugged in and work. Only one works at a time. Any ideas here?! There super bright!
Old 10-10-2014, 09:53 PM
  #381
Harness.
Old 10-10-2014, 10:05 PM
  #382
MyGuti's Avatar
Harness.
Do you know for sure that the vled harness is compatible with these lights?
Old 10-10-2014, 10:16 PM
  #383
Yes.
Well, I don't use VLEDs harness although some here do.
I use iJDMToy's harness. Much cheaper, and gets the job done.
Option R3 when ordering.
http://store.ijdmtoy.com/LED-Daytime...rl-decoder.htm
Old 10-10-2014, 10:21 PM
  #384
MyGuti's Avatar
Yes.
So you used IJDMToy's harness for these lights and it works? The ones Frosty provided the coupon code for....from gt Lighting
Old 10-10-2014, 10:35 PM
  #385
Check the pictures from above
Old 10-11-2014, 10:05 AM
  #386
Frosty's Avatar
It is still my understanding that the lights will work with the 6v power of the OEM wiring, but will not reach their FULL brightness unless you use an aftermarket, 12v Harness (either VLEDs or iJDMToy).
However, even with only 6v, the lights are still rather bright. Here is a picture of a 9th Gen Civic using these LEDs in his 6v DRLs with NO 12v harness or load resistors whatsoever.
Old 10-11-2014, 06:29 PM
  #387
acupower's Avatar
I actually prefer to have them slightly dimmer as DRL so this works for me. On a side note, I just put in LED fogs and I also got the radio interference issue. So I ordered some ferrite beads from ebay:
10pcs TDK 5mm Clip ON EMI RFI Filter Snap Around Ferrite NEW | eBay
When I receive them and install them I will report back with my findings.
Old 10-11-2014, 10:08 PM
  #388
carbngrytl's Avatar
Ordered a set for my fogs. Went to install them today and one of the bulbs doesn't work. Sent them an email, just waiting to hear back.
Old 10-12-2014, 11:50 AM
  #389
Mr. Detail
Scottwax's Avatar
Not sure if this has already been answered, 10 pages is a lot to go through, but are the LED headlights compatible with reflector (halogen) headlight housings? If it's plug and play, that's a lot easier and cheaper for me than retrofitting my headlights and upgrading to HIDs.
I already know how good LED lights are, I road bike and use one on my helmet and one on my handlebars.
Old 10-12-2014, 01:16 PM
  #390
Frosty's Avatar
Yes, they are absolutely compatible (plug-n-play) with halogen housings. That's the only place I've seen them used so far (I'd be very interested in seeing someone try them in a projector housing though).
Scottwax (10-12-2014)
Old 10-12-2014, 05:06 PM
  #391
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,245 Likes on 1,031 Posts
Are you thinking/planning on using them in your 04 Accord? Would be very interested in your thoughts/results if you move forward.
Old 10-12-2014, 05:53 PM
  #392
carbngrytl's Avatar
If they are good to use as an everyday headlight, I'd consider putting them in my 96 Integra projector headlights.
Old 10-12-2014, 11:19 PM
  #393
Mr. Detail
Scottwax's Avatar
Cool, thanks. Just don't want to be "that guy" with all the glare.
Yes, in my Accord. Wanted to do HIDs but no one makes (that I can find) a true plug and play HID ready headlight housing so I'd have to retrofit mine. And LEDs use even less power and last even longer so if I can simply swap out the halogens for LEDs that would be much more economical.
Probably order them when I get back from Arizona, heading there on Saturday of this coming week.
Old 10-13-2014, 08:59 AM
  #394
vietxquangstah's Avatar
What about projector headlights from eBay?
http://m.ebay.com/itm/380986936164?nav=SEARCH
Old 10-13-2014, 09:18 AM
  #395
Mr. Detail
Scottwax's Avatar
Too many projector headlights really aren't that good, know a lot of people who've had issues with light being too dim, not properly aimed, etc. Plus the LED strip IMO is equivalent to stick on fender vents.
Guess I'll try LEDs first and see how that goes. Less than $100 and a lot less work.
Old 10-13-2014, 09:25 AM
  #396
Jackass's Avatar
Don't worry, you will be that guy.
Check the pics in the first page. These will glare like a mofo to oncoming traffic. Although they probably won't be nearly as annoying as HIDs since they don't put out quite as much light. Being "compatible" with a reflector housing in this instance is that they fit and they do "reflect" light forward....but not in a perfect manner.
Old 10-13-2014, 09:36 AM
  #397
They glare like crazy if you use them at night in the DRL.
I only use them during the day, of course, and then switch my low beams on so nobody gets blinded.
Old 10-13-2014, 11:21 AM
  #398
NBP04TL4ME's Avatar
Agreed and have been thinking about doing the same for our Accord the kids use.
Old 10-13-2014, 05:13 PM
  #399
Mr. Detail
Scottwax's Avatar
I've seen pics someone else with a 7th gen Accord posted on another board. Cut line was a bit fuzzy but much more defined than the picture on the first page. But if glare will be an issue, I'll have to retrofit the headlights.
Old 10-14-2014, 10:54 PM
  #400
Jackass's Avatar
This is a great point I hadn't even considered when I replied about glare. It is a complete non-issue for those that are using them only for DRL.
Quick Reply: Best LED's on the Market! Who Needs HID's?!
