12 Volt Battery Charging System Problem
This warning light just started appearing during my last three drives. It appears as soon as I start the car. Battery is under 1 year old. Could this mean bad alternator? All electronics are working and there is no trouble starting the car. OBD meter did not pick up any error codes. As you can see in the pic, only 46,266 miles. Car is a '14 PAWS.
Forum Contributor
Received 1,391 Likes
See the following TSBs in the 2014 TSB thread:
TSB 14-028 - i-MID Reads “12 Volt Battery Charging System Problem” with DTC P16E3
TSB 14-034 - i-MID Reads “12 Volt Battery Charging System Problem” with DTC P154A
https://acurazine.com/forums/third-g...letins-971953/
NJ-RLX (04-13-2019)
Grandpa
Received 2,609 Likes
I don't know when this started, but my dealer said that it's SOP now to replace the battery sensor every time the battery is replaced.
Chans (04-16-2019)
Thanks, George. I just checked my receipt for the battery replacement. Apparently my Acura dealer did not get that memo from corp. The battery sensor was not replaced with the battery.
OBD2 apps and some radar detectors show voltage. I was monitoring the voltage drop in the RL from 14 and change to 12 and change when driving. Is suspected the alternator failing as it should always read 13+ when the engine is running. Similar with a hybrid, although there is no alternator.
snoopalupe
03-01-2019 10:51 AM
