2008 RDX Electrical Issues... Please Halp
Old Mar 6, 2019 | 06:25 PM
JSweatt's Avatar
3rd Gear
RDX had no issues when I bought it used. Suddenly, battery can’t hold a charge. I had it jumped a couple times and made long distance trips after each jump so alternator will refill battery. Still won’t hold a charge. Dash lights up both “check battery” light and “check SH-AWD” (super-handling all wheel drive) light, but no other dash lights.
I buy and install a new battery, same specs. New battery dies in a week. I buy a new alternator and install it myself (seemed simple enough). Battery continues to die and I continue to jump it. Thought it might be Bluetooth constantly drawing power from battery (read online that this is a common problem with 2008 RDXs), so I disabled Bluetooth. No change.
I check the amperage put out by the battery at rest. Sure enough, parasitic draw. I recheck the draw after removing individual fuses. After removing fuse #23 (labeled simply “BACK UP”) from the under-hood fuse box, parasitic draw is gone.
Can someone please tell me what “BACK UP” is? What systems does it affect to have no fuse in there?
Old Mar 6, 2019 | 07:13 PM
Poveiro's Avatar
Old Mar 6, 2019 | 07:32 PM
When you 'disabled' bluetooth, how'd you do that?
Old Mar 7, 2019 | 10:55 AM
JSweatt's Avatar
3rd Gear
removed the HFL module from the center console
Old Mar 7, 2019 | 10:57 AM
JSweatt's Avatar
3rd Gear
Originally Posted by Poveiro
Sweet! Thank you! All of these systems were indeed disabled.
Old Mar 7, 2019 | 03:59 PM
Poveiro's Avatar
@JSweatt you welcome
Old Mar 8, 2019 | 08:57 PM
CSmoney28's Avatar
CSmoney28
That’s a lot of stuff to disable, is there another fix for this?
Krizonic
May 14, 2011 03:50 PM
Karanx7
Apr 2, 2011 05:20 PM
Thomasv
Dec 11, 2009 05:17 PM
