12 Volt Battery Charging System Problem
Old Apr 13, 2019 | 09:25 AM
NJ-RLX's Avatar
This warning light just started appearing during my last three drives. It appears as soon as I start the car. Battery is under 1 year old. Could this mean bad alternator? All electronics are working and there is no trouble starting the car. OBD meter did not pick up any error codes. As you can see in the pic, only 46,266 miles. Car is a '14 PAWS.
Old Apr 13, 2019 | 12:58 PM
EE4Life's Avatar
Forum Contributor
See the following TSBs in the 2014 TSB thread:
TSB 14-028 - i-MID Reads “12 Volt Battery Charging System Problem” with DTC P16E3
TSB 14-034 - i-MID Reads “12 Volt Battery Charging System Problem” with DTC P154A
https://acurazine.com/forums/third-g...letins-971953/
Old Apr 13, 2019 | 07:13 PM
NJ-RLX's Avatar
Thanks!
Old Apr 14, 2019 | 09:36 AM
George Knighton's Avatar
Grandpa
I don't know when this started, but my dealer said that it's SOP now to replace the battery sensor every time the battery is replaced.
Old Apr 14, 2019 | 09:57 AM
NJ-RLX's Avatar
Thanks, George. I just checked my receipt for the battery replacement. Apparently my Acura dealer did not get that memo from corp. The battery sensor was not replaced with the battery.
Old Apr 23, 2019 | 12:30 AM
snoozabelle's Avatar
Snoozabelle
I just replaced my battery but not the sensor. Should I be replacing that too?
Old May 17, 2019 | 12:16 AM
Naveen Jain's Avatar
5th Gear
Any idea - what was the underlying issue.
I have similar issue with 2015 Acura MDX.
Old May 18, 2019 | 05:29 PM
5th Gear
Now the battery died and the car won't start.
Wondering if the problem is battery or battery charger or alternator.
Any suggestions?
Thanks,
-Naveen
Old May 19, 2019 | 06:19 PM
pcloadletter's Avatar
OBD2 apps and some radar detectors show voltage. I was monitoring the voltage drop in the RL from 14 and change to 12 and change when driving. Is suspected the alternator failing as it should always read 13+ when the engine is running. Similar with a hybrid, although there is no alternator.
Old Jun 7, 2019 | 05:13 PM
NJ-RLX's Avatar
The dealer diagnosed the problem as faulty battery sensor and replaced it free of charge.
00TL-P3.2
Nov 6, 2025 02:49 PM
Dan Ruths
Mar 10, 2019 12:21 PM
JSweatt
1G RDX Problems & Fixes
Mar 8, 2019 08:57 PM
snoopalupe
Mar 1, 2019 10:51 AM
AlanW
1G RDX (2007-2012)
Feb 28, 2019 02:51 PM
