Windshield Wipers in snowy locations
Maybe some of you up north could help with this. Whenever we expect snow and/or ice down here in the Chicago area, we try to leave our wipers in the "up" position (somewhere on the glass) so we can easily clean around them or get them unstuck from the glass. The old tried and true trick was to pulse the wiper and then turn off the car. Unfortunately, with the RDX, the wiper returns to the well at the bottom of the windshield. I've tried a couple of different things but nothing works. Anyone suggestions?
By the way, the wiper design with the hood is truly stupid engineering. You can't get the wipers out of the well far enough to remove the snow without actually opening the hood. The designers must have all been born and raised in southern states. Knuckleheads....
Thanks for any ideas.
Before shutting off the engine, push the wiper stalk upwards and hold; while holding the stalk upwards, press the engine start button to shut off the engine. After that, the wipers should be positioned in the maintenance mode so you can lift up the wipers.
Winter driving survival test:
Remove frozen slush from the driver's-side windshield wiper in the following fashion:
• While driving at moderate speed, roll down driver's-side door window.
• Start wipers.
• Reach around the window frame, grab the wiper when it swings around to that side, pull it away from the windshield and let it smack back into the windshield with its spring action.
• Repeat until the wiper is clean. Or until your fingers freeze solid, whichever comes first.
• Start wipers.
Jonathan Korber (11-12-2019)
Just put the wipers into the service position. It’s in the manual guys. Most European cars are like this as well.
Edit: to save you the trouble....
__________________________________________________ _____
2019 RDX Tech SH-AWD. Lunar Silver Metallic / Espresso
Spray deicing fluid on the windshield before it snows or after while you have the heat on defroster including the blades. I do it every winter before it snows and it help a lot.
I use something like this instead:
https://www.amazon.ca/Windsheld-Windshield-Protector-Windscreen-Protection/dp/B07Y3DWC57/ref=asc_df_B07Y3DWC57/?tag=googleshopc0c-20&linkCode=df0&hvadid=335919178016&hvpos=1o7&hvnetw=g&hvrand=14075502927889377396&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9000914&hvtargid=pla-838209467692&psc=1
In general, (not RDX related), start the car with fan in the defrost mode, while waiting slightly tap the wipers with a snowbrush to loosen the ice, give it 1 or 2 minutes and start driving, ice should start to melt as the windshiled warms up. Never understood the wipers in the up right position thing.
The following 2 users liked this post by flames9:
blexann (11-12-2019),
bluntman72 (11-12-2019)
Snow sensing didn't work well on my previous IS 250 either. It did very well with rain.
Remote start, especially with Auto Climate on, would help melt the ice. But just in case for winter driving, pack one of these (or similar de-icer) in the car, and one in the house or backpack/bag (in case the car's doors are iced shut parking outside).
9th Gear
By putting the blades in service mode and pulling them up for the night so they wont stick, you can't remote start the car to warm it up, the blades will rip the hood... STUPID DESIGN.
Ron A
02-05-2020 08:56 AM
glitchsys
2G CL Problems & Fixes
06-07-2010 11:17 PM
