USB Splitter on Infotainment?
Old Dec 1, 2019 | 10:50 AM
Waetherman's Avatar
2020 RDX White/Espresso
I haven't been using the USB for a memory stick with my own music, but the idea is appealing, especially since I just got a 64gb stick so I could upgrade the maps and it has no use otherwise. But I don't want to have my USB stick in there, only to have to remove it to use my ACP. Does anyone know if a USB splitter (aka hub) can be used to connect multiple devices to the infotainment system at the same time, i.e. a USB stick for MP3s and a phone at the same time?
I'm thinking something like this;
Old Dec 1, 2019 | 02:09 PM
Funz51's Avatar
Expanse me
Is this a splitter? you got a link?
I have written about this before.
I have tried this:
https://www.amazon.com/Anker-Individual-MacBook-Surface-Notebook/dp/B071G83CNN/ref=asc_df_B071G83CNN/?tag=hyprod-20&linkCode=df0&hvadid=309743296044&hvpos=1o4&hvnetw=g&hvrand=8370889608375131463&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008536&hvtargid=pla-562896822129&psc=1 https://www.amazon.com/Anker-Individual-MacBook-Surface-Notebook/dp/B071G83CNN/ref=asc_df_B071G83CNN/?tag=hyprod-20&linkCode=df0&hvadid=309743296044&hvpos=1o4&hvnetw=g&hvrand=8370889608375131463&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008536&hvtargid=pla-562896822129&psc=1
but b/c it is a hub, even though you can turn one off and the other on, the car detects it as a hub, and says 'no-go'. I have looked at actual splitters that enable a keyboard and mouse work with different computers upon a manual switch. They look a bit cumbersome...
Old Dec 1, 2019 | 02:13 PM
Funz51's Avatar
Expanse me
here is a possible candidate...
https://www.amazon.com/UGREEN-Selector-Computers-Peripheral-One-Button/dp/B01MXXQKGM/ref=sr_1_4?keywords=usb+manual+switch&qid=1575231157&s=electronics&sr=1-4 https://www.amazon.com/UGREEN-Selector-Computers-Peripheral-One-Button/dp/B01MXXQKGM/ref=sr_1_4?keywords=usb+manual+switch&qid=1575231157&s=electronics&sr=1-4
The only pain is the 5volts it needs to operate. maybe tap off the lower USB and run a line up.
Old Dec 1, 2019 | 02:39 PM
Waetherman's Avatar
If hubs are detected and not allowed, I don’t think there’s a solution.
Thanks for the research!
Old Dec 1, 2019 | 03:10 PM
Funz51's Avatar
Expanse me
what I am saying is I think there is.
https://www.amazon.com/UGREEN-Sharing-Peripheral-Switcher-Computer/dp/B01CU4QCRS/ref=sr_1_4?keywords=2+port+usb+switch&qid=1575233997&s=electronics&sr=1-4 https://www.amazon.com/UGREEN-Sharing-Peripheral-Switcher-Computer/dp/B01CU4QCRS/ref=sr_1_4?keywords=2+port+usb+switch&qid=1575233997&s=electronics&sr=1-4
no power supply needed.
just a few short patch lines. should work as well as a hub. It is not a hub. The car can only use one peripheral at a time, so this switch should work, since thats what it does. I might just grab one to try...
Old Dec 1, 2019 | 03:26 PM
Waetherman's Avatar
Well let me know how that goes. I have an HDMI switcher that works that way, so maybe it would work. But I also have a USB hub that has switches like that, but I think it still works as a hub - it’s just that the switches turn certain ports off.
Old Dec 1, 2019 | 03:38 PM
Funz51's Avatar
Expanse me
right. it is a hub if it has only one input and multiple outputs. If you look at my first link, that is the hub I tried, with little switches (switches there for convenience). When the car plugs into it, it asks if it is a hub, and if the response is yes, then it shuts it down. I believe the usb switches are just a hard wire switch with an electronic internal switch. The car still sees one peripheral. It makes sense, I just could not find a switch a couple months back. Now I see there are a few.
Old Dec 1, 2019 | 03:43 PM
Waetherman's Avatar
Oh I see. Looking forward to your report!
Old Dec 24, 2019 | 09:36 AM
Funz51's Avatar
Expanse me
My report is grim.
I purchased and tried
https://www.amazon.com/gp/product/B07S7YNN3S/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07S7YNN3S/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
The system did not complain about a HUB, but it did insist that I plug in a valid usb device.
So another 'no-go' hack for the time being.
Old Jan 6, 2020 | 07:59 AM
Dan J's Avatar
6th Gear
Any solution?
Has anyone figured a workaround to use a usb splitter/hub so I can use the Iphone with Apple car play AND also use a USB drive to play music?
Old Jan 6, 2020 | 08:05 AM
kboo74656's Avatar
You can’t. It’s in the manual. Put the music on your iPhone. It has storage space.....
Old Feb 21, 2020 | 02:54 PM
kboo74656's Avatar
Found this little nugget in the Developer Diagnostic screen! I enabled it but I don’t have a USB Hub to try it out!
Old Feb 21, 2020 | 03:46 PM
NooYawkuh's Avatar
Skeptic
What was the default setting? Was it disabled before you enabled it?
Old Feb 21, 2020 | 03:59 PM
kboo74656's Avatar
It was initially disabled and I enabled it. Now all I need is a USB Hub to try it out.
Old Feb 21, 2020 | 06:40 PM
Funz51's Avatar
Expanse me
you can go ahead and try it, I already have. It did not work for me. I even tried a USB switch which is not a hub and that didn’t work either. I enabled /disabled also.
Old Feb 21, 2020 | 07:18 PM
kboo74656's Avatar
Did you try it on the other usb outlets??
Old Feb 21, 2020 | 07:25 PM
Funz51's Avatar
Expanse me
did not bother, they are only power.
Old Feb 21, 2020 | 07:32 PM
kboo74656's Avatar
Well it was worth the try. Maybe there is a software aspect that has to be “turned on” for it to work??? I’m no super tech geek just a slightly average geek!!!
Old Feb 21, 2020 | 08:00 PM
Funz51's Avatar
Expanse me
that was my guess also. Look earlier in this thread and see all the tests we did. Go for it!
Old Feb 21, 2020 | 09:46 PM
NooYawkuh's Avatar
Skeptic
Yeah, poke around those menus and you'll see provisions for a world of shit that's simply not implemented in the RDX. It appears they may have aspirations for lots of future expansion. Makes you wonder if there's wiring for data from those other USB ports to a hub in the head unit. All they might have to do is develop the driver software. There are already separate menus for Bluetooth and USB audio on the home screen.
hobbes88
Jun 20, 2025 04:36 PM
dcmod
3G RDX (2019+)
34
Jul 9, 2020 11:26 AM
nore03
May 4, 2016 02:10 PM
SilverJ
Oct 11, 2015 06:17 PM
DerwoodEE
20
Sep 13, 2009 10:05 AM
