Safety Recall: 2019 RDX Fuel Pump Motor
2020 RDX White/Espresso
2020 Tech, no notice of any recall. But I guess if this is like the system updates, only half of us will get notified, and only half of those will be able to apply a fix.
@Gate 17 @bluntman72 can you post a screenshot?
See TSB 20-026 - Safety Recall: 2019 RDX Fuel Pump Motor in the 2019 TSB thread.
https://acurazine.com/forums/third-g...letins-970256/
Waetherman (05-29-2020)
Interesting that it’s only 2019, and the fix is “replace the fuel pump” presumably with a 2020 part? Is there a difference?
This looks like a fix to some of the early limp mode reports. I understand it probably took them awhile to determine the cause and I'm glad to see them issuing this safety recall
Important to remember the sudden limp mode fail affects 2020 models too.
2019 advance here. I didn't get any notice in my Acuralink app. I also downloaded the PDF regarding the recall. It said check the VIN number, but I don't see the list of affected VIN number. ???
Recalls have a history if being expanded. I would not be surprised if this started with some 2019s, then got expanded to include all 2019s, the expanded again to include 2020.
I’m going to do some research tomorrow (unless someone has already done it to save me the trouble) to figure out if there any difference between 2019 and 2020.
I imagine this answer hinges on whether or not this is a staggered recall that will eventually get all '19 and '20 vehicles, or just a VIN range. If it's a range, they've determined a batch is bad for some reason.
knock on wood I havnt had any stalls, but I imagine the people that were, that this was the cause
Quick research suggests that the fuel pump is (unsurprisingly) the same in the 2019 and 2020. It also appears it was used in the 2018 and 2019 Honda Accord which also had a 2.0 turbo. I don’t know enough about all the various engines used by Honda/Acura to know if this is the same engine, but I think it is.
I guess there’s the possibility of a “bad batch” - I don’t know if any Honda Accords that have had a similar problem, and one would think that Honda would be aware of there were since this part has been in use for a few years. And it could be something particular to the RDX related to the way it’s tuned. But remembering the Takata airbag recall, this could also just be the tip of the iceberg for a broader recall.
Good that their addressing the issue. How much does this repair typically cost?
The part retails for about $450, and it looks pretty easy to replace but I’m sure any shop would charge for at least a couple hours of labor.
1.2 Hours flat rate labor is quoted in the TSB. AFAIK that's what the dealer will get from Acura, in addition to reimbursement from the part. And I doubt Acura pays retail for warranty parts.
But the TSB cites constrained supply of the part.
Agree this is likely a bad batch manufacturing issue, not a design issue.
Whether it has anything to do with "limp mode" problems, dunno. TSB makes it sound like it either runs or it doesn't, but info is very sparse. AFAIK "limp mode" means it runs but at reduced power.
The mention of the impeller swelling makes this recall sound very similar to these recalls. I wouldn't be surprised if this isn't the same pump used by all these manufacturers.
https://www.carcomplaints.com/news/2...mpellers.shtml
The following 3 users liked this post by GW208:
Oh boy. Nothing yet for mine, but same description applies. And no problems aside from acceleration lag under some conditions, but I doubt a fuel pump will fix that. OTOH I'd be happy to be wrong.
Hi,
I set up the appointment with my Dealer for tomorrow at 9 am, but I did this on line, so I plan on calling the dealer this morning to confirm the time and to talk with service to make sure they have the part needed on hand. I saw on Facebook that one guy had went to the dealer only to be informed that they would have to order the parts needed. It a pretty good ways to my dealer, so I want to know they are ready to do this now.
Hi,
I also got one of the first 2019 Advance model. I just verified with the dealer that they have the parts and will install a new pump tomorrow. I’m sure you will get a recall soon. Mine actually came from my dealer by email.
I just saw another story about this on Car & Driver, they say owners with the effected vehicles will be notified by the end of July.
https://www.caranddriver.com/news/a3...l-pump-recall/
Fuel pump
I went to dealer this morning and had the fuel pump kit installed. Plan on about 2 hours which included a car wash and vacuum. I can’t tell any difference, but I wasn’t having any problems before. Hope this may be of use to someone. Be safe!
Received 1,026 Likes
Production dates May 21, 2018 to February 12, 2019.
https://static.nhtsa.gov/odi/rcl/202...0V314-8555.PDF
So I suppose I am included, even though I haven’t been notified yet. The NHTSA site does not show a recall yet for my VIN.
I hope that's true. But I find that idea somewhat suspicious.
Would they really put different basic components, like a fuel pump, in different trim levels at the same time? I don’t think so. I think that my tech is, mechanically, identical to an advance as it relates to engine components. They probably are just rolling out the recall in some order that makes sense to them.
