Outside Temp gauge stuck
Old 06-10-2019, 11:07 PM
Dereileak's Avatar
Anyone having there outside temp gauge get stuck for awhile, mine usually gets stuck at like 71 for the first 5-15 minutes of driving then it will start to adjust slowly, not sure if there is something wrong or it’s just programmed weird
Old 06-11-2019, 08:56 AM
Madd Dog's Avatar
Received 1,024 Likes on 714 Posts
It only takes mine 2 or 3 minutes to get to ambient temperature when driving.
Old 06-11-2019, 11:17 AM
Yotrek's Avatar
Normal..no worries
Old 06-12-2019, 04:18 PM
Dereileak's Avatar
Seems like some days it’s quick to update, others it sits for awhile stuck at a temp that is about 10 degrees off
Old 06-12-2019, 04:56 PM
Received 8,584 Likes on 6,630 Posts
take it to the dealer
Old 08-12-2019, 07:26 PM
3rd Gear
Carlos Avila's Avatar
having the same issue, it's been stuck at 91 degrees for days and the outside temperature is above 100, I'm in Texas. This car is crap.
Old 08-12-2019, 07:38 PM
JB in AZ's Avatar
I forget where, but there is an adjustment for the temp in the settings.....worth a try?
Old 08-12-2019, 07:39 PM
JB in AZ's Avatar
All my recent cars have done this when it is right after a car wash or a rain.
Old 08-12-2019, 08:05 PM
Skeptic
NooYawkuh's Avatar
I've had this happen occasionally with every car. It usually clears the next time I start the car. If it doesn't, bring it up the next time you're at the dealer. Personally, I wouldn't bring it in for just this.
Old 08-13-2019, 10:32 AM
zroger73's Avatar
The outside air temperature indicator has several internal modes that it selects depending on conditions. Some light reading is attached for your enjoyment.
Old 08-13-2019, 12:11 PM
3rd Gear
Thanks JB, I've tried everything but no success, will have to take it to the dealer
Old 08-09-2020, 04:14 PM
6th Gear
gkgindfw's Avatar
Hi Carlos - did you get this issue resolved. I'm having a similar issue. I'm in Texas as well. My RDX won't seem to go above 94 degrees on the outside temp reading.
Old 07-29-2022, 11:36 PM
amobofone's Avatar
Not sure if you still have your Acura with the temperature problems, but it is easily fixed by replacing your ambient temperature sensor. This is a $20 part that is located directly behind the bumper and in front of the radiator. It's as big as a lighter, and as easy to replace as looking up under your bumper, unplugging the old one, and plugging in the new one. And just like that you will see your temperature correctly displayed in your car and your new sensor will allow the right amount of AC to pass through the cabin. There is a good YT video on replacing it, I did it in an RDX and saved hundreds from what a dealership would have charged:
ttps://www.youtube.com/watch?v=X7x_TwoRYRQ&list=PLHw0rocHXDHGy6Cte5SwtN1A V72PTGxRI&index=2&t=5s
Old 07-29-2022, 11:37 PM
amobofone's Avatar
See my suggestion on changing the ambient temperature sensor.
Old 07-29-2022, 11:39 PM
amobofone's Avatar
This is so easy and cheap to fix by simply replacing your ambient temperature sensor. This is a $20 part that is located directly behind the bumper and in front of the radiator. It's as big as a lighter, and as easy to replace as looking up under your bumper, unplugging the old one, and plugging in the new one. And just like that you will see your temperature correctly displayed in your car and your new sensor will allow the right amount of AC to pass through the cabin. There is a good YT video on replacing it, I did it in an RDX and saved hundreds from what a dealership would have charged:
vr6vdub
02-11-2011 05:18 PM
BEAR-AvHistory
08-22-2007 03:45 PM
Newcleannow
1G TSX Problems & Fixes
20
10-12-2006 02:26 AM
sjkforever
08-03-2006 09:03 AM
Un-Kut
11-02-2004 07:41 AM
Quick Reply: Outside Temp gauge stuck
