Infotainment issues getting worse
Hoping someone has some suggestions for me. I installed the D.1.2.2 update without incident -- but immediately thereafter, had a variety of problems, the most annoying being that CarPlay would crash (or appear to) -- basically, whatever I was doing through my iPhone would stop, the CarPlay icon on the Acura screen would dim, and then a few seconds later (without any intervention from me), it would restart. Other issues included phantom phone calls that were hung up preventing use of the infotainment system, and inability to use the left wheel on the steering wheel to change channels -- it would either say system unavailable or just not work, and then sometimes 30 seconds later, advance by however many clicks I had done while it wasn't working. The CarPlay crashing would happen probably every 10 minutes. This clearly started upon installation of the D.1.2.2
Then, two days ago, I installed the new iOS update and went to 13.6. Now, the CarPlay situation is worse. When it crashes, it stays down for much longer, probably over a minute or so. During this time period, it is like the USB port is dead. The phone doesn't charge, even if I unplug it and replug it. I can't get audio by playing via USB, rather than CarPlay. Eventually, but much longer than the previous crash style, it comes back to life. This is superdisruptive, especially when I am using GPS (Google Maps), which is often. It is bad enough that I am considering using the built-in nav, which I do not like at all.
Any suggestions at all? Is it worth a call to the dealer? Should I try to download D.1.2.2 from the website to a USB stick and see if that helps?
Normally I'd say to take it in and have the dealership deal with it, but I'm not sure what they can do other than replace the entire unit (if they'll even do that). There's no shortage of complaints about the infotainment system, and if someone had a fix you'd better bet it would make its way around here like wildfire.
You could try a few things:
1) Try a different phone to eliminate your phone being the culprit.
2) Try a different USB cable to eliminate that as being the culprit.
3) Try doing a 3 finger reboot of the system.
Other than that...I'm not sure what else there is to try. The system works fine for some people (I suspect many don't actually use it all that much, and if you don't use something, it's less likely to have issues), but for some it has all sorts of non-deterministic problems. If you can consistently reproduce it, document it, and escalate the problem to no avail, you might be able to lemon law the car if you're desperate for a way to get out from under it.
The following 2 users liked this post by fiatlux:
19 RDX A-Spec (02-03-2021),
Tesla1856 (08-13-2020)
If none of this changes anything, I think dealer service needs to dig into the USB hardware of the car. I don't think any software glitch can cause the phone not to charge. ( But I've been wrong before, so if anyone knows different, please share! )
AFAIK if the phone doesn't charge, that means the problem is in the physical lightning-USB connection to the car. Everything else rolls downhill from this. Try cleaning the port on the phone, try unplugging and replugging the USB end of the cable as well as the lightning connector end. Try a new cable.
i haven’t tried the dealer yet, because this is one of those things where they will have to drive around for 20 minutes and hope it happens. Grrrr.
Try a new cable. I was having a connection issue with Android Auto, and even though I was "certain" I had a good cable, after several weeks, I tried a different cable, and so far I have not had the issue again. TRY A DIFFERENT CABLE.
BigOil (11-05-2020)
will do. I had a similar issue with a phone not connecting to my Mac, and even though it was a new Apple cable, I tried a different cable and it worked.
I will try those things (have already tried unplugging and replugging both ends), but the phone only stops charging for a minute. When CarPlay is working, the phone charges.
I had the same issue a few weeks ago; did a factory reset of the system including pulling the audio system fuse for 10 minutes. No problems since. Pulling the fuse may not be necessary, since I did it primarily to solve the clock offset issue (see this TSB: http://www.urvi.net/forumfiles/SB/B19-050.PDF)
I’ve found that on 1.2.2 CarPlay (granted I’m on iOS 14 beta) works perfectly fine every time as I head to my destination, and fails every time on the way back. Would love some engineering explanation as to why that is. Really hoping that a big software update is on the way to coincide with the TLX release.
wmkim (11-07-2020)
I’ve been waiting on an update, because it’s so inconvenient to go to the dealer, especially knowing they probably won’t be able to fix it. But I feel like my problem is so strange in that it started with the Acura update and then worsened with the Apple update. And now it’s so bad that I might not be able to avoid going to the dealer. My next step is trying with a non-Apple cable, although I was using a brand new Apple cable. And trying with a different phone. And I’ll try the factory reset if someone tells me how to do it. The three finger reset did not help.
Skeptic
![](https://cimg3.ibsrv.net/gimg/acurazine.com-vbulletin/800x613/applecarplay_eaba58f7529ccebacf412e38b19d8581bc49c9e3.png)
Infotainment CarPlay possible solutions
I have had a lot of the issues we are all complaining about. Here is what has worked for me:
1. If the system freezes up or becomes glitchy- I have removed Fuse #37 under the dash, near the hood release. It is for the infotainment system. This may get your system unfrozen and allow you to do the next step.
2. Factory Data Reset- Go to Settings, System, Factory Data Reset. This will get you back to the original infotainment settings.
3. TURN OFF Bluetooth while using Apple CarPlay. I filed a complaint with Acura. Once they got back to me, 2 weeks later, one of the solutions they offered for CarPlay cutting out was to make sure the system wasn't fighting between CarPlay and Bluetooth.
Seems pretty basic, but this got my infotainment system to run solidly for a few weeks......until it happens again : )
Switching off Bluetooth doesn't really help if you're having CarPlay issues. You have to update the infotainment system and do factory reset; version D1.2.1 and above fixes a conflict between the USB audio app and CarPlay which causes the disconnects.
I find it amazing that this is still happening. CarPlay works perfectly in many other vehicles. Wonder if the TLX release will bring some solution.
TLX features different graphics for Acura Watch in the gauge cluster and has additional settings for the custom drive mode and interior lighting. That being said, I’m a bit nervous about it after my RDX CarPlay experiences (being in IT I’m very patient too) when considering the Type-S.
CarPlay works flawlessly for me any time I use it, albeit, I barely use it. I've heard CarPlay issues crop up on every automaker across the board. Honda isn't alone with these issues. Some people get lucky, while others not so much.
Pretty sure (was it in the leaked "Dealer Video") that the the 2021-TLX with Tech-Package NAV Head-Unit was slightly upgraded over recent RDX. I don't use CarPlay, but this base-unit is what facilitates it.
I'm just glad there are no more "Acura DVDs" (maps and firmware) to load like models from 6 years ago. Sounds like it is all downloaded over wireless these days.
Skeptic
Bought a new Iphone11 yesterday. Reset the infotainment system and plugged it in with the new cable. Carplay ran for about 5 minutes on Google maps then quit, the same as before. So no change with new Iphone, cable and a reset.
BigOil (11-05-2020)
new iPhone
I just changed to an iPhone from a samsung galaxy. I was able to connect to apple car play on my 2018 honda odyssey but it will not connect to my 2020 rdx. It says car play unavailable. I have tried changing cords and reconnecting my phone. My wife has the same iPhone 11 and her phone will connect. I'm not sure what the issue is. Apple ran a diagnostic on
my phone and they will call me back next week. I was able to connect to CarPlay on my sons corolla.The rdx was the only car it wouldn't connect to.
Skeptic
