'Official HOUSTON thread'
Old Aug 31, 2010 | 11:26 PM
  #1641
Dat Boi Ralph's Avatar
2004 SSM FTMFW !!!!
Oh I see well my drop is around that I'm on Tein S-Tech springs, My other car I took it to this one place in Pasadena but I forgot how much they charged me.
Old Aug 31, 2010 | 11:39 PM
  #1642
nspec_ya4's Avatar
Regional Coordinator (Texas)
Ralph. if u can see some camber in ur tires, then u'll need a camber kit forsure. or if u want, u can leave it like that but ur tire will get inner wear faster.
if ur not gonna get a camber kit, then there isn't really any need to get alignment done right away. They can pretty much do nothing about camber, unless u have the kit.
so if ur not gonna get a camber kit, dont get alignment unless ur car doesnt drive straight.
Oh and Firestone sucks. They have never gotten a single alignment right, specially if u have a lifetime alignment, because then the mechanics will want u to keep coming back so they can keep getting paid on it, again and again.
I had that warranty on my previous car, my brother's car, and a few other friends had it. No one ever got their alignment right. It would work fine after we left the shop, but with a few days, it was back to what it was.
Old Sep 1, 2010 | 06:50 AM
  #1643
TLDude876's Avatar
Chapter Leader (Houston)
I have new shocks and springs in my closet but all of this talking is making me nervous and want to change my mind about going lower. I just had to buy 4 new tires because my alignmeny was off in the rear and damaged my tires.
Old Sep 1, 2010 | 10:11 AM
  #1644
VIP typ-S's Avatar
When are we getting together again ? I missed this past weekend and it sounds like I didn't miss much, but I would like us to put something together that's has plenty of parking and maybe not too far west. Maybe a photo shoot too !
Old Sep 1, 2010 | 10:17 AM
  #1645
powerflow's Avatar
Wiggy Wiggy Wiggy
Anytime you change the ride height on the car, you need to get an alignment. Lowing the car, or adjusting the height through the suspension changes the suspension geometry. The most notable problem is the Toe angle. Bad Toe alignment will eat up tires quick.
So, it is important to get an alignment no matter what. The Toe must be corrected after lowering, both front AND rear.
For a 3G TL, it is a good idea to get a camber kit for the rear. 3G's have had problems with rear alignment due to the suspension. Lowing can accelerate or increase this issue, that's why I recommend to get a good rear camber kit like Ingalls. That way the Toe AND Camber can be adjusted for the rear. A little negative camber is OK, but too much will wear tires faster than normal. Still bad camber will not wear tires like bad toe, way out of spec toe is like saying by by to your tires.
Lowering a car is no problem if you do it right the first time. I've had my 3G dropped the first week I owned it. 40K later I've had no issues. I also get non-direction tires so I can do a modified X tire rotation.
Also doing it right means having people like C&C work on your car. There is no comparison between places like C&C and Firestone, ect.
Old Sep 1, 2010 | 10:38 AM
  #1646
nspec_ya4's Avatar
Yeah but lowering a car doesn't change ur toe, only camber.
I'll double check soon.
Old Sep 1, 2010 | 10:42 AM
  #1647
powerflow's Avatar
Wiggy Wiggy Wiggy
Nope, lowering does change the toe.
When you change the height, the susp geometry changes which includes toe angles.
Old Sep 1, 2010 | 12:22 PM
  #1648
TLDude876's Avatar
So no camber kit is needed for the fronts?
Old Sep 1, 2010 | 02:43 PM
  #1649
powerflow's Avatar
Wiggy Wiggy Wiggy
Depends on how much you plan to drop it or how particular you are about the alignment settings. 1.50" or so drop, a front camber kit is not needed.
I'm dropped about 1.75" without a front camber kit, and I'm fine. My front camber is right at the factory tolerance on the negative side. I have an Ingalls camber kit on the rear set to almost match the front camber.
Old Sep 1, 2010 | 04:57 PM
  #1650
TLDude876's Avatar
I am planning to use h&r sport springs. 1.4F and 1.3R. Means I only need the rear correct?
Old Sep 1, 2010 | 06:25 PM
  #1651
powerflow's Avatar
Wiggy Wiggy Wiggy
Yep. You'll be fine without a front camber kit.
Old Sep 1, 2010 | 08:09 PM
  #1652
hksdrager's Avatar
6th Gear
hey powerflow what side of town are you on? I want to try to drop this car friday so i can be ready for coffee and cars. let me know. thanks mate
Old Sep 1, 2010 | 08:34 PM
  #1653
paulonfiya's Avatar
Bada$$VTEC very nice drop in personal
Old Sep 1, 2010 | 09:52 PM
  #1654
powerflow's Avatar
Wiggy Wiggy Wiggy
West side, Westheimer / Royal Oaks area. I can take a look at it and help you. But, I can't do it Friday, I could take a look at it on Friday though. I"m still moving and I have zero stuff at my place to work on cars. On a car like that I would rather take a look at it, then make a plan. I've worked on a few NSX's but's it's been all body / paint work. Removing the shock assembly should be pretty easy. But, I don't what parts you plan to install. Honestly my place might not be a good location to do the work, I can help though.
Old Sep 1, 2010 | 10:24 PM
  #1655
TLDude876's Avatar
I'd like some help installing my new springs. I can bring food, drinks, chicks etc. Seriously though, I'll even shell out cash if required.
Old Sep 1, 2010 | 10:25 PM
  #1656
GIOVANNIPR1's Avatar
6th Gear
Talking About meeting
[quHi i move from Orlando FL and i try to find some club ,i ahve 3rd generatio TL -05 ,Please let me know where u guys have meeting so i can go to meet everybody ,Thanks in Advace.ote=nspec_ya4;10096230]finally were getting some action here!
what day do you guys prefer?
meet monthly?
we can do something like saturday mornings, or nights.
how does Nov. 1st sound? its a saturday morning. may be meet up at around 10 or 11 may be a little bit later.
if we get 15 or more people we can also have a dyno day. get 2 pulls for 35 or 45 bucks each.[/quote]
Old Sep 1, 2010 | 10:45 PM
  #1657
6th Gear
Hi am new ,did u guys still met saturday 10 to 2 pm in katy (frys) please let me know thanks in advances.
Old Sep 1, 2010 | 10:50 PM
  #1658
nspec_ya4's Avatar
hey man. we'll have a meet pretty soon, probably in two to three weeks. it will be a saturday night meet. starting at about 5 or 6 pm.
Old Sep 2, 2010 | 12:14 AM
  #1659
Bada$$VTEC's Avatar
OMG-6SPD
We should be having one on the PZ Meet day right Nauman?
Thanks Paul,loved your car too.
Old Sep 2, 2010 | 08:44 AM
  #1660
kostya.lyt's Avatar
After I installed my springs, my alignment was waaaaay off, and while it was settling, I had the alignment done a few times. I always ask for the spec and sheet and go talk to the Tech. I know it's not optimal, but it's cheaper than paying full price for a full alignment. Plus I'm still on stock shocks, so new shocks will be happening soon.
I'm down for a meet once it's a little cooler.
Anybody going to Coffee and Cars this weekend?
Old Sep 2, 2010 | 09:02 AM
  #1661
TLDude876's Avatar
What springs did you install? Did you get a camber kit? If not, do you have drastic tire wear in the rear? I am planning to
install h&r sport springs with a brand new set of oem shocks and I keep getting mixed responses on camber kits.
Old Sep 2, 2010 | 10:30 AM
  #1662
hksdrager's Avatar
6th Gear
Ok no problem I think I'll just rent the spring compressor. Anyone that's on the nw side that can help I sure would appricate it
Old Sep 2, 2010 | 11:04 AM
  #1663
2004 SSM FTMFW !!!!
I would like to go, perhaps we can gather up and roll up there. When is this ? and where at ?
Old Sep 2, 2010 | 11:17 AM
  #1664
too bad i'm in arizona.....til tuesday.
Old Sep 2, 2010 | 11:22 AM
  #1665
hksdrager's Avatar
6th Gear
A few of us from the nsx club will b up there were meeting up at 7. Will b in the diginal parking area across from the sushi close to the feeder. But dam want to lower my car before I go lol
Old Sep 2, 2010 | 11:28 AM
  #1666
2004 SSM FTMFW !!!!
That would be awesome if a few NSX and TL's would roll up there. Where is the location ?? this is at 7 am right just making sure. c'mon guys anybody want to roll up there ?
Old Sep 2, 2010 | 11:53 AM
  #1667
TLDude876's Avatar
I'll be in Dallas for the holiday wknd . Maybe next time
Old Sep 2, 2010 | 12:08 PM
  #1668
6th Gear
Thanks bro for answer me ,please let me know when ok, am in kingwood tx.
Old Sep 2, 2010 | 12:14 PM
  #1669
6th Gear
Hi everybody i have a bend rim,somebody a good place to fix and maybe how much ,thank in advance.
Old Sep 2, 2010 | 03:02 PM
  #1670
hksdrager's Avatar
6th Gear
Bent rim 100$ American wheel and tire I think it's called they did one for me.
Old Sep 2, 2010 | 03:30 PM
  #1671
hksdrager's Avatar
6th Gear
its in uptown park near the galleria. nsxs will be parked in the shaded tree area close to the feeder across from the sushi area. if ur coming get there a 7am or you will be driving around in circles
Old Sep 2, 2010 | 03:59 PM
  #1672
2004 SSM FTMFW !!!!
Sounds good hopefully we can a few other guys to join us as well
Old Sep 2, 2010 | 04:56 PM
  #1673
SaifTL's Avatar
7 am? damn thats early for a car meet!
Old Sep 2, 2010 | 07:07 PM
  #1674
cu0ngsayz's Avatar
the next meet is going to be at PZ.. i just dont know a exact date yet...
Old Sep 2, 2010 | 07:55 PM
  #1675
6th Gear
Thank HKSDRAGER for the information, i will check that place
Old Sep 2, 2010 | 08:56 PM
  #1676
hksdrager's Avatar
6th Gear
hey what side of town are you on?
Old Sep 2, 2010 | 09:07 PM
  #1677
nspec_ya4's Avatar
man this thread has started going too fast for me to keep up. lol.
Old Sep 2, 2010 | 09:09 PM
  #1678
nspec_ya4's Avatar
I might go to C&C with a friend and a couple of exotics.
if not, then I'll take my car. We can all roll together, but there might be no space to park out cars. Unless we get there super early.
Car and Coffee
September 4th, saturday morning at Uptown Park, we'll have to get there at about 7:30
Planet Zero Meet
Possibly Sep 19th or 26th, Saturday Night.
Old Sep 2, 2010 | 10:30 PM
  #1679
2004 SSM FTMFW !!!!
^ Hey Nauman Im down for Saturday morning let me know if you decide to roll up there send me a text
Old Sep 2, 2010 | 10:45 PM
  #1680
kostya.lyt's Avatar
I may be there around 8 in the Bug. I'll try to catch up with you guys regardless.
