Windows7 - Best User & Partition Strategy
Old Feb 28, 2012 | 11:26 AM
Bearcat94's Avatar
AZ Community Team
Edit: Problem 1 solved. New question in post #5
Got a new PC Laptop a couple days ago.
I want to go back to an "out of the box" configuration - no partitions, no user data, no user added/changed settings.
How do you do that in Windows7?
Basically, I want to wipe the thing clean and start over.
Oh, btw, @ Microsoft, Bill Gates and Microsoft Windows.
Old Feb 28, 2012 | 11:43 AM
coykiam's Avatar
Did it come with a recovery disc? if it didn't there is usually a recovery in one of the partitions. You can access it by hitting F8 and choose it from the menu.
Old Feb 28, 2012 | 11:51 AM
STL+3.0CL's Avatar
Matt
You should be able to boot to the recovery partition and create a recovery disc. Depending on what type of laptop it is, it may have this feature in the OS itself. some Toshibas for example have a recovery program that lets you create a recovery disc from the start menu. But Im betting you'll have to hit F8, boot to the recovery partition, create a recovery disc, and then boot to it (F12).
Old Feb 28, 2012 | 11:56 AM
Bearcat94's Avatar
AZ Community Team
Yes, I did a 'recovery', but it didn't remove the HD partition(s).
I found the feature I needed though under the Admin Tools.
Old Feb 28, 2012 | 12:01 PM
Bearcat94's Avatar
AZ Community Team
Ok, so for a home based PC with 2 primary users, what is the best strategy as far as partitions and user accounts?
No gaming, just general document and/or internet use.
One user will want an alternative language input/use set up.
Old Feb 28, 2012 | 12:11 PM
Rock2534's Avatar
I don't really see why you would need more than one partition. Just make 2 separate user accounts and call it a day.
Old Feb 28, 2012 | 12:21 PM
STL+3.0CL's Avatar
Matt
I don't think there's a need for multiple partitions. For the alternative user language profile, you should be able to go into regional and language> keyboards and languages and change the default language on the second profile.
Old Feb 28, 2012 | 12:38 PM
ChrisJ's Avatar
Just make 2 accounts...No need for partitions...
Old Feb 28, 2012 | 12:41 PM
Bearcat94's Avatar
AZ Community Team
So why on the very first boot up out-of-the-box did it Suggest/Recommend creating a second partition?
Old Feb 28, 2012 | 12:42 PM
ChrisJ's Avatar
For data recovery purposes...They want a separate partition for backups...
Old Feb 28, 2012 | 12:44 PM
STL+3.0CL's Avatar
Matt
How big is the drive?
Old Feb 28, 2012 | 12:45 PM
ChrisJ's Avatar
Myself personally I back up to a separate drive...I am not a fan of holding the OS and backups on the same physical device...
Old Feb 28, 2012 | 12:46 PM
Bearcat94's Avatar
AZ Community Team
There was a "recovery" drive already setup.
Not too big - 500GB.
Old Feb 28, 2012 | 12:47 PM
ChrisJ's Avatar
They will recommend setting up a secondary partition to store user data and have the OS on its own partition...And if there isnt a recovery partition it will recommend that as well...I didn't realize you already have one...
Old Feb 28, 2012 | 01:04 PM
ez12a's Avatar
the overexplainer
what manufacturer is this, just for reference?
but yeah, simply adding another user within Windows is fine. You can control quotas for each user folder.
partitioning up your drive doesnt really help, it's not like the data is safer in one partition vs. the other in case of hardware failure, and you lose flexibility in managing your hard drive space. One gripe I have with companies that ship without physical recovery media and rely on the recovery partition.
Old Feb 28, 2012 | 01:32 PM
Bearcat94's Avatar
AZ Community Team
Well, this is what it said or what I thought to do - put the user data on it's own partition. BUT I couldn't figure out how to get Windows7 to put MyDocuments anywhere but C:\.
So I had this space partitioned off for user documents, etc. and Windows wanted to put everything on the wrong drive anyhow. Hence the original questions.
Originally Posted by ez12a
what manufacturer is this, just for reference?....
Samsung.
http://www.samsung.com/us/computer/l...NP300E5A-A02UB
Old Feb 28, 2012 | 01:34 PM
ChrisJ's Avatar
This may help ya
http://headstrongfarm.hubpages.com/h...g_My_Documents
Old Feb 28, 2012 | 01:41 PM
ez12a's Avatar
the overexplainer
http://www.sevenforums.com/tutorials...-location.html
edit: ninjaed lol.
Old Feb 28, 2012 | 01:52 PM
#1 STUNNA's Avatar
Sanest Florida Man
I have my OS and program files on my SSD drive and all my media on a separate 1TB drive.
Then just moved location the user folders to point at the data drive instead of the C drive.
Old Feb 28, 2012 | 01:55 PM
ChrisJ's Avatar
Thats the point with a SSD though...I am maybe reaching here but I am assuming at 500GB the OP is talking about a SATA 2.5 drive...
calrow
May 3, 2017 10:21 PM
InFaMouSLink
Nov 11, 2015 12:19 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
AcuraKidd
Sep 25, 2015 11:18 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
