Windows XP Question
Old Dec 19, 2002 | 08:57 PM
MikeSwing's Avatar
Windows XP Question
Does anyone out there know how to stop the Messenger Service pop ups? Ever since I upgraded to XP, this crap pops up all the time when my PC is idle. Thanks in advance fellas.
Old Dec 19, 2002 | 11:05 PM
srika's Avatar
Moderator Alumnus
well - if you're running the latest version (5.0) - open the main Messenger screen, go to Tools menu, Options, General tab, and uncheck all the "Alerts"..... this should stop them from coming up... I just tested this on mine, it worked. I think even if you're running a version 4.x - this will still be the same process to disable the popups.
Another thing I noticed about this damn MSN messenger, Micro$oft, under the cover of the "upgrade" from 4.7 to 5.0, enabled two default options, both of which change the way MSN behaves when you turn on and/or login to your computer. The first change makes the MSN window come up by default, and the second change makes this new lame "MSN Today" window come up. At first I thought it was a change not disable-able (is that a word? hehehe) - but then I noticed there were two checks for these two pesky windows in the same tools, options, general tab. I admit I do use MSN messenger - but I much rather have it silently remain in the background, than pop up these annoying screens.
delobbo
Old Dec 19, 2002 | 11:09 PM
soopa's Avatar
The Creator
dont think thats what hes talking bout delobbo.
mike... yes... go to computer management... services... and disable the messenger service. simple. thank someone else here for the tip... been discussed in previous topic.
Old Dec 19, 2002 | 11:23 PM
srika's Avatar
Moderator Alumnus
oops.... yeah.... THAT. it's funny because someone had asked me earlier today about this MSN messenger alerts issue _I_ was talking about, and see THAT is why I assumed that is what was being talked about HERE.......
delobbo
Old Dec 20, 2002 | 03:54 AM
sswany's Avatar
If you're running the newest updates of XP and messenger, it will finally let you uninstall it. Do that! MSN messenger is SATAN. Use AIM, it's the only way to go.
Old Dec 20, 2002 | 09:56 AM
MikeSwing's Avatar
thanks fellas. It frickin annoying
Old Dec 20, 2002 | 04:02 PM
Strahan's Avatar
Disabling the messenger service won't do it. Messenger service isn't for MSN Messenger, it's for Windows messenger. If you don't have the latest patches and whatnot and cannot uninstall it from Add/Rem programs, here is the manual way to uninstall it:
rundll32 advpack.dll,LaunchINFSection %WinDir%\inf\msmsgs.inf,BLC.Remove
Once that's done, click Start, Run type gpedit.msc and hit OK. Under Computer Configuration open Administrative Templates, Windows Components, Windows Messenger. Double click "Do not allow Windows Messenger to be run" and enable. Double click "Do not automatically start Windows Messenger initally" and enable. Close group policy and you're done.
BoricuaTL
Apr 8, 2016 01:08 PM
06TLMatt
Oct 2, 2015 08:14 PM
truonghthe
Oct 1, 2015 03:13 AM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
