Weird iPad2 occurrence.
Old Nov 2, 2012 | 11:04 PM
2001AudiS4's Avatar
I was just on anther forum typing a reply to a thread on my iPad when the page all of a sudden jumped to another page in the forum. I pressed the back button and was returned to where I previously was along with the text being present that I already typed. I pressed on the screen to continue typing, and the keyboard was now in split keyboard mode. I had to go into the settings and turn off "split keyboard". Is there a shortcut or something that would cause this? I thought the only way to enable it was from within the settings menu.
Old Nov 2, 2012 | 11:11 PM
Sarlacc's Avatar
The Third Ball
If you drag the keyboard up it splits manually. You might have brushed it in the right place.
Otherwise...ghost in the machine
Old Nov 2, 2012 | 11:59 PM
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
bottom right hand key on the keyboard can be manipulated multiple ways.
Any iPad owner who attempts to type while standing knows it's a cumbersome task; stabbing at the keyboard with one finger while holding the iPad with one hand is less than ideal. Fortunately, Apple made things easier in iOS 5 with a split keyboard. How it works:
  • Whenever the keyboard is prompted, literally pull it apart with your thumbs. Or, long-press the keyboard button (bottom right) and select Split.
  • To go back to the regular keyboard, push it back together with your thumbs, or long-press the keyboard button and select Merge.
  • You can now undock the keyboard when it's in the way of something on the screen. Long-press the keyboard button and select Undock. You can then split the keyboard, if you like.
Old Nov 3, 2012 | 12:14 AM
2001AudiS4's Avatar
Dragging the keyboard does nothing. At first holding the keyboard button did nothing as well. Once I went back to settings and set the keyboard split option to on, I was ale to hold down the keyboard button and select to merge it. I guess I must have hovered on that button without noticing. Thanks.
Old Nov 3, 2012 | 04:00 AM
Whiskers's Avatar
Go Giants
Call Level 4.
Skirmich
Oct 1, 2015 12:59 PM
kb1rl
Sep 30, 2015 10:17 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
