Tell me more about MoCA
Old Dec 5, 2012 | 10:56 PM
Mizouse's Avatar
i hate my wireless N network, always drops off and is generally slow as hell. performance was fine when i was wired, but when i switched to cable I had to relocate the router to my living room downstairs and switched to a N network.
i was thinking of a powerline adaptor, but i heard of issues if say the router is on a different circuit than the plug where you put the other adapter. also plugging in some networking device into an electrical outlet and then into my devices just scares me.
basically ill be hooking up my TV, TiVo, PS3, Apple TV and PC onto it.
only thing odd is that it says it supports up to 270Mbit/s but only includes a 10/100 ethernet port kind of defeats the purpose of the speed.
unless there is a model of this MoCA adapters with a gigabit port
Mizouse's Avatar
my house is not wired for ethernet btw.
Old Dec 6, 2012 | 09:02 AM
The Dougler's Avatar
Unofficial Goat
how many sqft is your house? You should be able to setup a N-network to cover the whole thing without issues. Your router may on be able to broadcast in one mode so if a G computer hops on the network the whole thing switches down to G for all computers. At my parents place which was 4500sqft I could cover the whole house with 1 router that was in a far off corner, which leads me to believe your issues are arising from the particular router you have and how it's configured.
Old Dec 6, 2012 | 09:22 AM
Scrib's Avatar
Administrator Alumnus
Are you running 2.4GHZ N? 5GHZ? Dual band?
I have two fourth gen airport extremes in my house and I get coverage 300 feet outside my house and down the street on my iPhone. So as mentioned above, I am leaning towards a config issue, a shitty wireless router or a combination.
2.4GHZ, you should be able to cover quite an area and penetrate everything.
Old Dec 6, 2012 | 09:27 AM
doopstr's Avatar
You should check to see what other routers are being picked up at your house and see what channels they are on. Try putting your router on a different channel.
Old Dec 6, 2012 | 09:41 AM
Unofficial Goat
This too, as a habit I throw mine on channel 11 for some reason it 90% of the time is a free. I live in a high density condo so there's all kinds of interference around us, but I've had no issues on my 2.4ghz G network.
Old Dec 6, 2012 | 09:48 AM
TeknoKing's Avatar
Look into Buffalo routers, cheap and strongest range allowed and custom firmware.... Covers 5,000 sq feet no problem. I use it in one of my concrete warehouse.
(Or you can always just setup an access point to extend the range of your current router)
Old Dec 6, 2012 | 10:07 AM
Mizouse's Avatar
Wireless in general has always been unstable for me. No matter where, what router and what device I've used it at.
I current have the previous gen AirPort Extreme base station running in dual channel iirc 2.4 and 5ghz
Old Dec 6, 2012 | 10:08 AM
Mizouse's Avatar
I can't even stream Netflix movies at 720p
Old Dec 6, 2012 | 10:23 AM
Scrib's Avatar
You should not be having problems with that router.
Old Dec 6, 2012 | 10:40 AM
Mr Marco's Avatar
Are you sure you're equipment is set for, or 'n' compatible. ^this sounds like you are on b or g.
Old Dec 6, 2012 | 10:44 AM
Scrib's Avatar
Or you live in a faraday cage...
Old Dec 6, 2012 | 10:57 AM
Unofficial Goat
you need to look at your configuration then. Do you have any cordless phones in the house? I bet your losing packets left right and center with interference. is your computer running lion? open wifi-diagnostics are start looking at what's happening around you.
Old Dec 6, 2012 | 11:34 AM
Mizouse's Avatar
I do, I have one of the newer Panasonic ones at 1.9ghz.
Does not cut out when on the phone.
All my computers are on wireless N. only device not N is my ps3 but that is never turned on anymore.
The one Mac we have us on mountain lion and my PC win 7
Btw I've had same problem back when I had AT&T DSL and now I have Comcast xfinity Internet. Also had the same issues with my older linksys wireless G router. Wired networking was flawless, so maybe i do live in a faraday cage
Old Dec 6, 2012 | 11:38 AM
Mizouse's Avatar
Speed wise it's fine, it's just that the wireless connection always drops out.
Old Dec 6, 2012 | 12:12 PM
Unofficial Goat
Start looking at what else is happening on wireless around you. Lion's wifi diagnostic gives lots of great info, I'm sure win7 has something similar too, just don't know what its called.
Old Dec 6, 2012 | 12:17 PM
Mizouse's Avatar
Ill try changing to channel 11
Old Dec 6, 2012 | 12:52 PM
Mizouse's Avatar
What's the realistic not theoretical top speed for wireless N anyways?
When I transferred an 8gb file over N it took 4.5 hours. Seems awfully slow.
Old Dec 6, 2012 | 01:37 PM
CGFebTSX04's Avatar
^On your TouchPad, install an app called Wifi Analyzer:
https://play.google.com/store/apps/d...YW5hbHl6ZXIiXQ..
It'll scan your area for all SSIDs and the channels they're using. It can recommend what better channel to use and how strong your WiFi signal is. You can probably use it to help minimize interference as well by moving your router around and checking the signal strength with the app.
Old Dec 6, 2012 | 01:51 PM
TeknoKing's Avatar
about 135mbps (yes don't let the advertisements fool you)-- around 17Mb/s
in your case you are getting about 500KB/s... (4mbps)... yikes
Old Dec 6, 2012 | 02:08 PM
Mizouse's Avatar
That's like B speeds
harvthesecond
Mar 2, 2014 10:13 PM
