Sys Admins, registering DLL in Vista
Old Mar 7, 2007 | 04:24 PM
Schizm's Avatar
Synaesthesia sounds sweet
When I try to manually register a DLL in Vista regsvr32 throws "The module abc.dll was loaded but the call to DllRegisterServer failed with error code 0x80020009"
I do have admin permissions and my paths are correct. There isn't much information out there to help me on this one. Hopefully one of you have run into this before. Thanks
Old Mar 7, 2007 | 04:31 PM
Billiam's Avatar
Big Block go VROOOM!
Are you attempting this from a command prompt or the Start -> Run box?
Even if you're using a command prompt, I think you may still need to right-click the shortcut and do "Run as administrator" in order to get actual full admin rights.
Old Mar 7, 2007 | 04:38 PM
elessar's Avatar
Return of the Ring
Hmmm... I've got no experience with Vista, but I looked up that error code using Visual Studio Tools. Unfortunately, it just says "exception occured"... gee, thanks! Have you tried searching on Google Groups?
Old Mar 7, 2007 | 04:48 PM
Schizm's Avatar
Yeah I tried GG and EE, thanks for searching VS for me btw.
Awesome! Nag screen later, it all worked out. I loaded the command prompt that way rather than from the Run line.
Looks like Vista will putting my left-click to some hellacious use. Drat, and I'm a Run line kinda guy
Old Mar 7, 2007 | 04:56 PM
elessar's Avatar
Return of the Ring
Glad you got it to work!
MilanoRedDashR
Oct 2, 2015 10:49 AM
emseecoy
Sep 29, 2015 12:39 AM
kev87a
Sep 26, 2015 02:30 PM
blackwarrior
Sep 26, 2015 09:09 AM
agupta3224
Sep 22, 2015 02:37 PM
