Rear facing Rack mounted Network Switch?
Old Nov 30, 2010 | 09:41 AM
2001AudiS4's Avatar
I am trying to find a network switch that is rack mounted, with nothing more then indicator lights on the front. I would like all the ports to face the rear of the rack. This would be going into an Audio/Video rack so it will not have any wires on the front. All the switches I have found are the traditional front facing switches. I probably only need 8 ports but will more then likely get a 16 port switch if I can find one. Does anyone know if one exists that will have the ports and power cable all in the rear?
Old Nov 30, 2010 | 10:28 AM
doopstr's Avatar
Never saw one. Mount it in the back of the cabinet and no one will see it.
Old Nov 30, 2010 | 10:33 AM
2001AudiS4's Avatar
Thats what I have been considering doing, but do not want it to interfere with any of the other equipment. The rack will have a decent amount of equipment in it. It may be my only choice though.
Old Nov 30, 2010 | 10:43 AM
doopstr's Avatar
Here you go!
http://www.pakedge.com/docs/SwitchBrochure_062810.pdf
Old Nov 30, 2010 | 11:08 AM
2001AudiS4's Avatar
PERFECT. Thank you.
Old Nov 30, 2010 | 11:12 AM
#1 STUNNA's Avatar
Sanest Florida Man
Yeah, I've seen one of those before. I remember seeing a switch that had the AC Port on the same side as the ethernet ports, I may have one here at the office if I can find it. if I remember correctly it looks very similar to the one in that PDF
Feb 25, 2020 09:57 AM
KB1_EJ6
Aug 28, 2016 08:25 AM
wilztlxs
Dec 1, 2015 09:16 AM
FC2012RDX
1G RDX (2007-2012)
Sep 4, 2015 02:05 PM
KillerG
Sep 4, 2015 02:02 PM
