Quick Photoshop Help
Old Oct 31, 2009 | 11:39 PM
mastertl's Avatar
I don't have a Ferrari in
If I have an image of scattered dots and shapes and I've used magic wand to select each individual image, is there a way to quickly turn all those selected shapes into individual layers?
Thanks.
Old Nov 1, 2009 | 06:36 AM
Anachostic's Avatar
Since a selection in PS, even if it is multiple non-contiguous areas, still counts as one selection, you would have to paste it all-or-none into a new layer.
If it was time consuming to select all the elements from the original, I would paste them all into a new layer, then duplicate the layer for each element, then go through the layers and clear all the elements except one.
If it's easy to select these elements, you can do the inverse and duplicate the original layer for as many elements there are, then go through each layer, select the element, invert the selection, then clear.
But I'm no Photoshop wizard either, so I could be totally wrong.
Old Nov 1, 2009 | 10:45 AM
Billiam's Avatar
Big Block go VROOOM!
When you have something selected, CTRL+J takes and puts copies of that selection up on a new layer. As Anachostic stated, you could then create duplicates of this resulting layer and remove portions of them leaving only one targeted object per layer.
Old Nov 1, 2009 | 11:41 AM
#1 STUNNA's Avatar
Sanest Florida Man
Or you could select each object one at a time and hit cmd + c which will a copy right above the original but in a new layer.
Old Nov 1, 2009 | 02:14 PM
Billiam's Avatar
Cmd/Ctrl + C is a simple copy to the clipboard in Photoshop like any other application. It won't do anything with new layers or anything else.
Old Nov 1, 2009 | 02:18 PM
#1 STUNNA's Avatar
Sanest Florida Man
Sorry I should've added the obvious. If he pasted it it would make a new layer with a duplicate of the object he copied in it. Or he could cut the object from the background cmd + x and then paste it which would cut the object from the background in a new layer.
Old Nov 1, 2009 | 06:52 PM
mastertl's Avatar
Ah thanks. I guess it'll just take me a while to change everything.
MilanoRedDashR
Oct 8, 2015 10:30 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
TLguy42
Sep 26, 2015 11:27 AM
