Problem w/ LCD Monitor!?!?!
Old Sep 30, 2004 | 01:07 AM
SeCsTaC's Avatar
styling on you
Hey guys, I just bought a LCD, and on boot I cant see anything until it comes ot the Windows XP Pro load screen. Anyone kno hoe to fix this? I need to see the POST screen and I need to go into BIOS also so anyone?
Old Sep 30, 2004 | 01:18 AM
AngryAndy's Avatar
I slap people
um, im not a computer wiz, but try setting the screen resolution to something low like 800 x 600 when your screen turns on and then reboot. hope it works
Old Sep 30, 2004 | 01:54 AM
spooky3ce's Avatar
Swift 3 B-A-N-G-E-R
When you first boot up your computer... try hitting F8 a couple times... that should put you in the setup... regardless if it shows or not... good luck...
Old Sep 30, 2004 | 08:33 AM
doopstr's Avatar
Does your monitor have an autosync or autosize button? Hit that during the post.
If your machine posts too quickly for autosize to work hit whatever button you need to hit to get your machine into the bios. Then do autosize.
Old Sep 30, 2004 | 02:52 PM
ArN 2000 TL's Avatar
Moderator Alumnus
Old Sep 30, 2004 | 06:51 PM
SeCsTaC's Avatar
styling on you
Thanks guys, I'll try this later
Old Oct 1, 2004 | 08:23 PM
caball88's Avatar
lcd's usually support certain resolutions. some will adjust automatically when the resolution is not quite supported. read the instruction manual and find out what resolution it supports. plug your old monitor in and set it to one of those resolutions. then turn off the comp and switch back to the lcd.
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
