Parallels and Boot Camp Issues
Old May 13, 2008 | 02:31 PM
Sly Raskal's Avatar
Unhappy Parallels and Boot Camp Issues
So yesterday I installed Parallels and unbeknownest to me, the version that ships is not the version you are supposed to use with Leopard and BootCamp.
http://www.parallels.com/en/support/desktop/leopard/
The version that shipped was Version 3.0 Build 4XXX, they have a newer build of 5600 that they say should be used with Leopard.
After installing Parallels and setting it up to use my already existing Boot Camp Partition, when I start up that VM, it boots up windows just fine, but when it gets to the login prompt for windows, I can't do anything. The keyboard and trackpad don't work at all. Also, the external Apple Aluminum keyboard I have doesn't work when attached and the tablet and external mouse I have don't work either.
Have any of you had this issue? I don't know what to do to fix the problem.
Side Note: After installing Parallels with the lower Build number and trying to run the VM, it did something to my Windows Installation and I had to do a repair on it and now it's all goofy. Now I gotta do a clean install on it.
Old May 13, 2008 | 02:49 PM
Sly Raskal's Avatar
Evidently I'm not the only one with the exact same problem.
Looks like I got some digging and homework to do.
http://forum.parallels.com/showthread.php?t=17034
Old May 13, 2008 | 10:34 PM
EmuMessenger's Avatar
Not sure how to help, but I am using VM Fusion and it found my BootCamp partition and has worked flawlessly from day one.
Running Vista Ultimate and 4GB RAM on a MB Pro.
Old May 14, 2008 | 05:38 AM
mastertl's Avatar
I don't have a Ferrari in
VM Fusion user here. Everything is fine on a 2GB MBP.
Is it a ram issue? Does it boot up otherwise fine from BC?
Old May 14, 2008 | 09:38 AM
Sly Raskal's Avatar
Prior to installing Parallels, everything was running fine.
I did install 4GB of Ram a while ago, but after that everything was running smooth for both OS X and Windows via Boot Camp.
Unfortunatly, I don't think there is anything I can do to repair this installation. I"m going to have ot re-install windows and try installing parallels again and see how it goes. If it doesn't work, I may just ditch it, eat the cost of the software and try VM Fusion.
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
CaliBud916
Sep 19, 2015 01:56 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Sep 17, 2015 10:16 AM
scionxb3003
Sep 14, 2015 01:52 AM
