Page File Usage History
Old Dec 2, 2009 | 02:39 PM
Shalooby's Avatar
Secret Agent
And PF Usage slowly climbs until it's maxed out. pos Dell laptop from work that has been pissing me off for two days.
The hard drive crashed the other day and they swapped it out with a new one from a new machine. This has been happening ever since.
What could be causing the PF Usage to slowly climb like that until it locks the system up and everything crashes?
I ran Malwarebytes' and it didn't reveal anything.
Help.;
Old Dec 2, 2009 | 02:47 PM
STL+3.0CL's Avatar
Matt
How much RAM is in the system? Is eliminating the page file not an option?
edit: I guess disabling the PF wouldn't be useful until you found the problem. N/M
Old Dec 2, 2009 | 02:54 PM
STL+3.0CL's Avatar
Matt
What is your highest memory usage process before it crashes? I would try watching your process memory usage tab in task manager and see if you can find it that way.
Old Dec 2, 2009 | 03:03 PM
rza49311's Avatar
I wonder what your page file settings are vs the amount of memory you have.
How much memory does the laptop have?
You can check the page file settings by right clicking my computer > properties > advanced > performance(settings button) > advanced tab > change button.
what are the values there?
Old Dec 2, 2009 | 03:21 PM
Shalooby's Avatar
Secret Agent
It's a P8400 running at 2.26 GHz
1.95 GB RAM
VM settings are:
Initial 2046
Max 4096
Old Dec 2, 2009 | 03:33 PM
rza49311's Avatar
Hmm, well all that seems fine..so this just started happening when you got a new hard drive? did they have to reinstall windows?
Old Dec 2, 2009 | 03:39 PM
Billiam's Avatar
Big Block go VROOOM!
For shits and grins you could try setting a static page file size (same initial and max values). I highly doubt it will have any effect on the issue you're encountering but it also probably won't hurt anything either.
Old Dec 2, 2009 | 03:46 PM
Anachostic's Avatar
Which process is using up all the memory? You should be able to see that in task manager. Also, you can turn on additional columns to show physical vs page memory used.
Old Dec 2, 2009 | 04:00 PM
stogie1020's Avatar
Needs more Lemon Pledge
are you out of room on the HDD?
Old Dec 2, 2009 | 04:53 PM
v6cord2k5's Avatar
seizure force field!
Did you arrange your icons by penis?
Old Dec 2, 2009 | 05:01 PM
Shalooby's Avatar
Secret Agent
I don't think they did. I don't know why the dork didn't just give me a new machine altogether. He pulled a hard drive from a new laptop, stuck that in my old one, and that was it. I did have to re-register MS Office. Maybe he activated a new version of Windows.
I'll try anything if I get shits and grins out if it!
It's strange, I see multiple versions of chrome.exe running. each using 20 - 40K of memory. That looks suspect..... I've removed and reinstalled chrome once.
Nope. Only about a quarter used.
Of course!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
UA7_Ando
Sep 28, 2015 07:53 AM
