Outlook PST question
Old May 13, 2005 | 10:35 AM
Scrib's Avatar
Administrator Alumnus
I have the PST file of a previous employee of my group on my C: drive.
How can I have that PST loaded into Outlook permanetly, without having to File ---> Open ----> Open Data File... each and every time I restart Outlook?
Thanks.
Old May 13, 2005 | 10:36 AM
zamo's Avatar
Houses Won't Depreciate?
import it to your current file. Use the import feature.
Old May 13, 2005 | 10:39 AM
tmk70's Avatar
Masshole
However, once you open it, it should stay listed in your Folder list in the left pane of Outlook...that's strange that it isn't.
Old May 13, 2005 | 10:44 AM
Rock2534's Avatar
right, once you add it to your email profile, it should open every time. you can have multiple pst files so that should not be an issue.
Old May 13, 2005 | 10:49 AM
Scrib's Avatar
By importing it, does it still stay on my C drive and not take up my disk quota on the server???
Old May 13, 2005 | 10:50 AM
zamo's Avatar
if your current PST file is on C drive, then yes.
Old May 13, 2005 | 10:52 AM
Scrib's Avatar
Mine is stored on an exchange server; remotely...
I just want to keep this seperate from my inbox and folders, and just always have it accesible...
Old May 13, 2005 | 10:56 AM
zamo's Avatar
ok, goto File Management in File Menu, and add that PST file.
You will have it permanently after that.
Old May 13, 2005 | 11:03 AM
Python2121's Avatar
The hair says it all
you can copy your pst's into your application data directory
Old May 13, 2005 | 12:46 PM
03typeS6spd's Avatar
misanthropist
tools -> services -> add -> personal folders is how i add mine
i didnt see file management under my file menu?
Old May 13, 2005 | 12:52 PM
zamo's Avatar
Maybe it is an option in Outlook 2003 only, so your approach is valid for older versions
Old May 13, 2005 | 12:54 PM
misanthropist
Maybe it is not an option in Outlook 2003, so your approach is valid for older versions
nice edit
i'm still on 2000 at work
Old May 13, 2005 | 01:04 PM
Whiskers's Avatar
Go Giants
File, Open, outlook data file and it should stick and should not be part of your quota.
Old May 13, 2005 | 01:35 PM
Rock2534's Avatar
you add a remote pst the same way you do a local one. just browse to it on the network. just make sure your pc has a drive letter mapping to the location.
Old May 13, 2005 | 04:18 PM
Scrib's Avatar
Interesting...
If I go to File ---> Open ----> Open Data File... the PST file doesn't stick upon relaunch of the application.
However, if I use File ----> Data File Management... it does work.
Anyhoo... Thanks all!
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
