Outlook 2010
Old Aug 20, 2015 | 02:03 PM
stogie1020's Avatar
Needs more Lemon Pledge
Outlook 2010
Anyone have Outlook 2010 installed that can help me test something?
I am seeing odd behavior on two machines with Outlook 2010 and was wondering if someone else could do a simple process to see if they can replicate.
1. Open Outlook 2010
2. In the search bar above your inbox messages, type a search you know will result in MORE THAN ONE search hits that are NOT in the inbox directly (should be in subfolders)
3. Click once on the any of the items shown as resulting from the search EXCEPT the very first one so that it shows in the preview pane.
4. Hover your pointer over the various email addresses in the header (To, CC, Your address, etc) for a few seconds and see if the window flickers, goes blank for a second and then puts you into the very first result item in the search result.
I have replicated this on two machines with Outlook 2010 installs and it happens exactly the same... Hweird.
Old Aug 20, 2015 | 02:05 PM
TacoBello's Avatar
Blame Ashley Madison.
Old Aug 20, 2015 | 02:36 PM
Anachostic's Avatar
FWIW, I could not replicate on Outlook 2007 on an old 32-bit XP VM.
Old Aug 20, 2015 | 04:39 PM
stogie1020's Avatar
Thanks for trying.
Old Aug 20, 2015 | 04:51 PM
Whiskers's Avatar
Go Giants
2010 was like 30 years ago.
Old Aug 20, 2015 | 04:54 PM
Outlook 2010
Tell that to my company.. We're still on 2007... That shit is like 50 years ago!
Stogie I can try on 2007 butt that's probably not going to give you the results you were looking for..
Old Aug 20, 2015 | 04:55 PM
Flipster23's Avatar
I have 10 let me try.
Nope nothing..
Old Aug 20, 2015 | 05:46 PM
stogie1020's Avatar
Hmmm... Weird.
Well, thanks for trying.
Old Aug 20, 2015 | 06:22 PM
No go here in 2007 either.
Old Aug 20, 2015 | 06:38 PM
stogie1020's Avatar
I would post a screen video of it, but there really is no way to sanitize it enough to prevent showing things I can't show...
Old Aug 20, 2015 | 06:43 PM
Create a .pst with test email messages and create a positive search result such that only those pop up?
RenoTL's Avatar
I don't have Outlook 2010 but tried to reproduce this in Outlook 2013 and it was fine. I did have the 2010 before and don't ever recall seeing this happen to me on any PC I used.
Old Aug 20, 2015 | 06:48 PM
On that train of thought... I'm wondering if your .pst is corrupt... have you tried repairing?
Old Aug 20, 2015 | 06:49 PM
stogie1020's Avatar
It happens on multiple different machines of mine all running 2010.
Old Aug 20, 2015 | 06:52 PM
Are the search results in your Inbox (within subfolders)? Have you tried search results in a archive .pst and do they exhibit the same symptom?
Just throwing out ideas that I would try if I were in your shoes
Old Aug 20, 2015 | 07:06 PM
stogie1020's Avatar
I don;t have an archive PST, just the active Inbox.
The problem ONLY occurs when i hover over a hyperlinked (blue) email address in the TO or CC field of the preview pane, and ONLY when I am viewing the results of a search..
It's as though there is some issue with the Outlook popup (your mini contact) that appears when you hover over a name in the header of a search result...
Old Aug 20, 2015 | 10:09 PM
Anachostic's Avatar
Does it do it when running in safe mode?
outlook.exe /safe
Other options: How to start Outlook in safe mode - Outlook Tips
Old Aug 21, 2015 | 10:52 AM
stogie1020's Avatar
Havent tried SM, good question.
Old Aug 21, 2015 | 10:53 AM
stogie1020's Avatar
Nope, does not happen in SM...
Old Aug 21, 2015 | 10:55 AM
Got any 3rd party add-ins?
Old Aug 21, 2015 | 11:10 AM
stogie1020's Avatar
Yes. Disabled them all and restarted Outlook and it still happened...
Old Sep 24, 2015 | 11:01 AM
stogie1020's Avatar
OK, another Outlook question...
Someone sends me an email with an address or a company name in it.
I want to be able to highlight the text, right click and choose "search with Google."
Is there a way?
Cut and paste into a google page is so 20th century...
Old Sep 24, 2015 | 03:21 PM
Doom878's Avatar
Search with Bing but I'm on Outlook 13. We are running Win 7.
Old Sep 24, 2015 | 06:51 PM
stogie1020's Avatar
Bing is like a giant donkey show. NO want.
Old Sep 25, 2015 | 07:19 AM
Doom878's Avatar
Me neither. I wonder if I could change it if my job didn't have admin control.
Old Sep 25, 2015 | 10:52 AM
stogie1020's Avatar
The web says there is a registry hack, which I tried, and it didn't work...
Old Oct 1, 2015 | 01:59 PM
Beelzebub's Avatar
use this one
Change Default Search Provider in MS Office 2013 Suite - Guiding Tech
I had done it before and had to search for the right page
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Office\15.0\C ommon\General]
"SearchProviderURI"="http://www.google.com/search?q="
"SearchProviderName"="Google"
cut and past that in to a *.reg file and import.
Old Oct 1, 2015 | 02:14 PM
stogie1020's Avatar
Appreciate the suggestion,. but I had already manually added that to no avail.
Old Oct 1, 2015 | 02:20 PM
Beelzebub's Avatar
weird. I made the changes and restarted outlook and had it there.
Are you getting the settings from a server?
Old Oct 1, 2015 | 03:11 PM
stogie1020's Avatar
No, standalone machine. Also, I made the change in the 14.0 folder as I don;t have a 15.0 folder ([HKEY_CURRENT_USER\Software\Microsoft\Office\15.0\Common\General])
Here is what I see when I highlight text in a message and choose "lookup"
Old Oct 1, 2015 | 03:20 PM
stogie, your outlook is all sorts of fucked up
Old Oct 1, 2015 | 06:19 PM
stogie1020's Avatar
Tell me about it...
If I work on a message long enough for a draft to be auto-saved, I am unable to attach anything to it! I have to start over and get it done in 3 minutes or less!
Old Oct 1, 2015 | 06:25 PM
Tell me about it...
Sounds like an efficiency booster to me
Old Oct 1, 2015 | 07:27 PM
stogie1020's Avatar
I don't know if I should laugh or cry...
Old Oct 1, 2015 | 08:08 PM
Beelzebub's Avatar
Yea it sounds totally messed up.
you might have to deinstall office and clean up all traces and reinstall
or you could just throw the machine out and buy a new one...
Old Oct 2, 2015 | 10:55 AM
stogie1020's Avatar
Meh, minor annoyances. Not worth throwing out the baby with the bath water... Yet.
Old Oct 12, 2015 | 09:05 AM
Company finally rolled out 2013.. (from 2007 )
Added the reg key and it worked perfectly for Search with Google! Thanks for heads up stogmeister and Beelzebubblebutt!
Old Oct 12, 2015 | 01:29 PM
stogie1020's Avatar
Based on how many licenses I hold and how infrequently I update them, I may simply start using Office 365.
Anyone regret moving to the cloud/app based Office from the standalone desktop version?
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
johnalfa
Nov 5, 2015 06:44 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
marinrain
ILX
Oct 6, 2015 12:36 AM
TLguy42
Sep 26, 2015 11:27 AM
