laptop problems...
laptop problems...
my dell notebook has this problem where the cursor moves on its own... it continually goes off the screen when I'm not even touching the computer. If I try to move the cursor I can kind of, but its being pulled off the screen the whole time.
I attached a mouse and keyboard to see if it was caused by me touching the comptuer, but that didnt' help. it still does it a lot.
anyone know why this would happen?
also... when I'm running it on battery power, if I run too many programs it just shuts off. yesterday I had outlook, word, and IE open... the second I tried to open an image file it just shut off.
any advice?
any advice?
its not from the mouse though... it happens whether the mouse is plugged in or not.
if I bang on the keyboard around the little touchscreen thing for the mouse sometimes it fixes itself, or goes to the other side of the screen... could something be pressing down on that sensor somehow?
Originally Posted by anothercls
Turn off the little cursor pad, and setup the battery warning to let you know it is going to turn off. You can create a battery saving profile for the laptop so it is less bright and runs slower as well.
I can turn off the cursor pad!?!
how do I do that?
and its not that the battery dies... yesterday the battery had about 97% power when it shut off. its like the cpu overloads and it just shuts off...
If it is the original load from Dell it should be in the system tray to turn it off.
Check to see if the fan is working, if it is not then the laptop is overheating and turning off due to that, sooner or later the MB will fry and Dell will come out to replace it.
fan is working fine, I checked that. I don't really care too much about the battery problem, this computer is going to sit on a shelf and not move so that doesn't really matter.
I just need to be able to control the cursor.
thanks for the advice...I'll try turning off the cursor pad when I get home.
yeah I've had a bunch of problems with this laptop. I haven't even used it in months because its been such a pain in the ass.
its now being delegated to home stereo networking use only
Originally Posted by BEETROOT
I read that to turn off the mouse touchpad thing I have to disable it in BIOS.
Anyone know how I change BIOS settings?
hit f2 ( i believe ) or startup it should be an option there, same place my case led color settings are
snorf
11-04-2019 06:44 AM
guji2
07-21-2002 10:51 PM
