HP ENVY 17" - need replacement
I ordered my friend a ThinkPad Yoga 15 like two months ago and he's been really happy with it and I thought it was good for the price when it was ordered, which would have left room for upgrading.
Price: $900 before tax
Core i7 Mobile CPU
8GB RAM
NVIDIA Discrete Graphics
256GB SSD
1080p Touch Screen
Has the Yoga hinge for laptop/tent/presentation/tablet modes
If I wanted something with Windows 10 I'd consider it, but my 2011 MacBook Pro handles what I need with 8GB RAM and an SSD. I'm also invested in the Apple ecosystem with that, iPhone, iPad, Apple TV, etc. so I like having a Mac for personal use. Did like my ThinkPad W too, but the Yoga is thinner and lighter for a Lenovo laptop.
Core i7 Mobile CPU
8GB RAM
256GB SSD
1080p Touch Screen
+100 on apple refurb
In many ways the refurbs go through more checking and testing than new from the factory. My current workhorse is a 15" MBP Retina mid-2012 that I bought as a refurb. Its been great.
Anybody have any thoughts on these?
Refurbished 21.5-inch iMac 1.4GHz dual-core Intel Core i5 - Apple
http://www.apple.com/shop/product/FE...-Intel-Core-i5
Some have 1tb fusion drive. Some just say 1tb hard drive
figured out roller
seems like i can graze the mouse top with my finger
it took al my favorites on my phone and loaded it here..AWESOME
however screen seems to big to move mouse pointer from side to side
Looks like backlight bleed. If it bothers you, you can exchange it.
Try adjusting mouse tracking speed in system preferences. This tutorial might help too with using mouse and doing gestures.
thank you
i read about it now and it seems some people who returned it had the same issue
DEFINITELY bothers me BIG time
ugh hate to lug this thing back again
thanks
i will do the tutorial today
should be very helpful
anything else you recommend for first time mac user?
Originally Posted by 2012wagon
just did the PRAM reset
I would say its 30% better but still bleeding on the bottom
If I exchange at the store can i ask them to open box there and show no bleeding?
So back to square one
Will be ordering a 21 iMac retina through the discount
When you order there are free keyboard options . Does that mean those are the bigger keyboards that are corded ?
When i was at bestbuy corded keyboard full size was $49
When I brought the magic board home it wasn't too small
Is 1tb fusion hd worth $100 over regular 1tb hd?
Any other specs you would recommend ?
If you can afford it, Flash storage would be best.
Choose Storage
Configure your iMac with a large Serial ATA hard drive, choose ultrafast PCIe-based flash storage for incredible performance, or get the best combination of speed and capacity by selecting Fusion Drive.
Flash Storage
Flash storage delivers significantly improved performance compared to a traditional hard drive — speed you’ll notice when you start up your iMac, launch an app, or browse your photo library. Flash storage also uses no moving parts, so it operates silently. For maximum performance, you can configure up to 512GB of flash storage on the 21.5-inch iMac or up to 1TB on the 27-inch iMac.
Fusion Drive
Fusion Drive combines speedy flash storage with a high-capacity hard drive. OS X intelligently manages what goes where, using the flash storage for files you access frequently and keeping the rest of your digital life on the roomier hard drive. Over time, the system learns how you work, so it tailors management of Fusion Drive to work best for you. You can choose a Fusion Drive of up to 2TB on the 21.5-inch iMac and up to 3TB on the 27-inch iMac.
The 1TB Fusion Drive pairs a 1TB hard drive with 24GB of fast flash — enough to store important OS X files and applications to ensure fast startup, near instant wake from sleep and quick application launching, with room left over for your most frequently used files and apps. The 2TB and 3TB Fusion Drives pair a larger hard drive with 128GB of fast flash storage, providing even more space for your most frequently used files. For the best performance, iMac systems with 32GB of memory should be configured with a 2TB or larger Fusion Drive or all flash storage.
Flash Storage
Fusion Drive
If you can afford to go SSD, even with a 1TB Fusion Drive, I'd do it. Although 24GB doesn't sound like much, the near instant load time at startup and for apps is awesome. And then you still have another terabyte for whatever else you keep on your computer. I have my MacBook Pro set up with a 128GB SSD for OS X and applications, and Windows. Then I took out my optical drive and put in the 750GB HDD that came with it for high-capacity internal storage. There can be a very slight delay if I play a song way down in my iTunes library or if I'm seeking files like in my downloads folder, but it's normally unnoticeable and I'm fine with it.
This is based on something I learned from my storage certification.
A lot of enterprise storage arrays (at least EMC arrays since that is what I worked on) use what is called FAST: Fully Automated Storage Tiering. What that is, is that it evaluates what types of storage you have (in enterprise it is usually Flash, SAS, and Near-Line SAS, from fastest to slowest, respectfully) and automatically places data in the different types of storage where it most makes sense, i.e. what you use most often stays on the fast, flash storage (like your OS) but then stuff that can take up a lot of space like documents, photos, and media files that can afford to have a slight lag are moved to the slower, mechanical storage device since a second or two lag to open a single file is normally less of an impact than delay to load the OS on boot or opening applications. It helps to optimize the use of solid-state storage since the price per gigabyte is still relatively high when compared to mechanical, platter hard disks. So, in a way, Apple's Fusion Drive in the iMac is very similar to what FAST does in enterprise storage deployments.
We all do...
