Excel Question
Old Jan 30, 2008 | 09:34 AM
sho_nuff1997's Avatar
I disagree with unanimity
Question Excel Question
starting where it is highlighted, i would like to create a formula that will give me the answer to column f (miles per tank) / column b (gallons) but it needs to change every row. is this possible?
does it make sense what i am asking?
thanks in advance!!
Old Jan 30, 2008 | 09:44 AM
svtmike's Avatar
in g40, enter "=f40/b40"
then copy and paste g40 to all of the cells you want to have the calculation. excel will change the formulas so that, for example, g41 will have "=f41/b41".
Old Jan 30, 2008 | 09:45 AM
leftride's Avatar
i want to ride my bicycle
so are you looking for:
F40/B32
F41/B32
F42/B32
F40/B33
F41/B33
F42/B33
etc...
i forgot to add that it cannot be the whole column, because i have different data above that
Old Jan 30, 2008 | 09:47 AM
thanks!
that was easy enough.
i think i had too much coffee today
Old Jan 30, 2008 | 09:48 AM
Shalooby's Avatar
Secret Agent
It won't be. Only the cells that contain the formula will display the results.
hornyleprechaun's Avatar
Bent = #1
So you only have 3 Miles per tank cells? If so you can absolute reference by pushing F4 then copying and pasting.
=$F$40/B32
=$F$40/B33
=$F$40/B34
etc..
Edit: Damnit.. at least you find out answer
Old Jan 30, 2008 | 09:54 AM
=$F$40/B32
=$F$40/B33
=$F$40/B34
etc..
ya i just decided to start it on my own. the car can do it, but i wanted to keep a record. i started the sheet to see how much i spent on gas and to figure my fuel consumption.
Old Jan 30, 2008 | 10:08 AM
cibs's Avatar
even easier than copy pasting is clicking on the cell you want to 'replicate' and then clicking on the little box that appears in the bottom right hand corner when your cursor turns to a + symbol, and then just drag as far as you want...
that works for formulas, dates, times, etc...
Old Jan 30, 2008 | 10:22 AM
how do i get rid of the #DIV/0 error?
Old Jan 30, 2008 | 10:43 AM
03silvertypeS's Avatar
Just delete it or fill in the cells referenced in the cell containing "#DIV/0" error. The reason you're getting that error is the one or both of the cells contained in the formula do not contain the data for the formula to work.
For example, if the cell contains the formula "=A1/B1", you will get an error if cell A1 or cell B1 is blank.
Old Jan 30, 2008 | 04:06 PM
The Dougler's Avatar
Unofficial Goat
I have another question for you pros. I've got a list of movie titles in a column, and want to make it so that if you click on the title it will open firefox and query that title on imdb. is there anyway to write a formula for this? I don't want to have to go through all the titles and have to manually hyperlink them.
Old Jan 30, 2008 | 04:16 PM
Jonesi's Avatar
Insert --> Hyperlink
done.
edit - Here's a link for reference.. And This Right Here Is a Hyperlink.. Text with a link embeded
Old Jan 30, 2008 | 04:21 PM
Q1911's Avatar
you should use a different program. its called "All My Movies" it inputs all the data right from IMDB and such forth. let me know if you want it
Old Jan 30, 2008 | 04:39 PM
Unofficial Goat
Does it run on MAC by any chance?
Old Jan 30, 2008 | 04:43 PM
Q1911's Avatar
sorry
Old Jan 30, 2008 | 04:51 PM
Unofficial Goat
found me one, Thanks!
Old Jan 30, 2008 | 11:22 PM
Bearcat94's Avatar
AZ Community Team
For row 40, if I understand what you're doing:
type the following in g40
=if(b40="","",f40/b40)
That says "If b40 is blank, then leave g40 blank, otherwise f40 divided by b40"
If you need to retain static references use the $ where needed.
Once done, copy the formula down as far as you want. When you fill in the "B" column, the formula will give a result.
Old Jan 31, 2008 | 07:49 AM
curls's Avatar
Someone stole "My Garage"
Definitely a cleaner way to do it, good job!
Old Jan 31, 2008 | 07:56 AM
excellent!
Thanks all!
Old Jan 31, 2008 | 08:24 AM
svtmike's Avatar
I find =if(iserr(f40/b40),"",f40/b40) to be more robust.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
rboller
Sep 23, 2015 02:49 PM
