Computer Sound Stopped Working
Old Nov 5, 2009 | 11:59 AM
subinf's Avatar
One on the right for me
First, as I start all my computer threads, I pretty much know nothing about computers.
A few months ago my AVG and Malwarebytes were doing their routine sweeps and picked up some spyware and apparently a virus. Nothing seemed to be wrong with my computer but after everything was cleaned up the sound stopped working.
I've noticed that when I turn the volume all the way up I get a little noise from the speakers but when I try to play anything - youtube, mp3, dvd, etc., I hear nothing.
What is odd is that when the computer makes a weird error - like when I hit three keys at once or something, I hear a beep. I went into windows sounds and tried the default sounds but I get nothing.
Just so no one thinks I'm a total moron - the volume is not on mute, I've tried to reinstall the sound drivers from Toshiba but the computer won't let me remove the old one.
So, any suggestions? I have a Toshiba Satellite Pro U200 with Windows XP.
Old Nov 5, 2009 | 12:07 PM
Anachostic's Avatar
Make sure you have "both" volumes turned up. There's the master volume - the one when you single-click the speaker icon, but there is also the Wave volume, which you can get to by double-clicking the speaker icon.
Old Nov 5, 2009 | 12:10 PM
subinf's Avatar
^ - Oh yeah, that is the other thing, the speaker icon on the bottom right no longer is there. I tried to put it back on the toolbar thing or whatever it is called but the computer told me I had to do it some other way - I've forgotten now how it said to do that
Old Nov 5, 2009 | 12:15 PM
Anachostic's Avatar
You can go to Control Panel>Sound and look for "Show speaker control in taskbar" checkbox or something similar.
Old Nov 5, 2009 | 12:16 PM
subinf's Avatar
Ok so I opened up the Sounds and Audio Devices Properties thing and went to Audio (the volume tab is turned up) and the default device is listed as SoundMax HD Audio. I click on the volume button and it says nothing is installed.
Could that be the problem?
Old Nov 5, 2009 | 12:19 PM
#1 STUNNA's Avatar
Sanest Florida Man
I think you have a problem with your speakers or the wire connecting to the speakers. the beeps you heard before probably came from the internal speaker inside your PC. Do you have the speakers plugged into the right hole? It should be the green one. If you want try plugging in another set of speakers or even headphones to see if you get sound.
Old Nov 5, 2009 | 12:21 PM
#1 STUNNA's Avatar
Sanest Florida Man
It seems to me as if your PC isn't detecting that there's something plugged into the speaker port. this is usually a fault of the speakers but maybe the port is bad.
Old Nov 5, 2009 | 12:22 PM
subinf's Avatar
I'm on a laptop. I've tried using headphones to get sound and I get nothing.
Apparently I'm missing a sndvol32.exe so I'm going to try and find out how I can reload that and see if that solves the problem
Old Nov 5, 2009 | 12:23 PM
#1 STUNNA's Avatar
Sanest Florida Man
If you have an XP install disc you can find it in there. Then place it in the correct folder.
Old Nov 5, 2009 | 12:24 PM
subinf's Avatar
I found the sndvol32 exe - which controls the master and wave volume. And it is fixed.
Thank you very much for pointing me in the right direction.
Old Nov 5, 2009 | 12:25 PM
subinf's Avatar
Thanks. I don't know what happened to my XP disc but someone on a computer forum had the file as a zip. I probably have another virus but at least my sound is working again.
Old Nov 5, 2009 | 12:37 PM
Vector02's Avatar
Also, Microsoft Security Essentials > AVG. By far...
Old Nov 5, 2009 | 12:39 PM
Gnate's Avatar
Custom User Title
once my sound driver got deleted on my xp pc, what a bitch that was, don't know why it happened either.
subinf's Avatar
Downloading now. Thanks.
Old Nov 5, 2009 | 12:44 PM
Bdog's Avatar
Not Registered
Start > System > Hardware > Device Manager> look and see if there is any ! or ? by Sound, video and game controllers. If there is, uninstall what has an error and restart your computer. You can try to update sound drivers also.
*Ok, didn't see you already fixed it, but usually you can delet the sound driver and it will install a new one and everything will work.
rockyboy
Aug 4, 2024 10:35 AM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
theinsvnity
Sep 10, 2015 10:22 PM
