Business internet Q
Old Apr 9, 2008 | 01:53 PM
JaredGMS's Avatar
Meat stick
Business internet Q
Ok, so we currently have 6 PC's all running TS to a non-local server, and of course it runs slow as hell because it's running over 1 DSL line.
We have 7 phone lines currently routed to our office.....IF we were to get 3DSL lines, and split those between the 6 of us, there shouldn't be any problems in speeds, right?
Old Apr 9, 2008 | 01:59 PM
Whiskers's Avatar
Go Giants
Depends on the speed of the DSL line...
Old Apr 9, 2008 | 02:02 PM
JaredGMS's Avatar
Meat stick
They will all be the same as the current....512U/384D
Old Apr 9, 2008 | 02:09 PM
Whiskers's Avatar
Go Giants
It will be 3 times faster How are you going to share 3 connections?
Old Apr 9, 2008 | 02:15 PM
JaredGMS's Avatar
Meat stick
DSL modem-->switch-->2pc's
Old Apr 9, 2008 | 03:27 PM
thunder04's Avatar
Sweet!
Would it be cheaper/easier to see if you can up the bandwidth on the single connection?
Old Apr 9, 2008 | 04:29 PM
stogie1020's Avatar
Needs more Lemon Pledge
Does your firewall load balance? Does your switch?
Old Apr 9, 2008 | 04:32 PM
Beelzebub's Avatar
That would be very confusing to set up with out a load balancing switch.
as your connection wouldn't know which path to take out to the internet as you can only have 1 gateway.
Old Apr 9, 2008 | 04:33 PM
JaredGMS's Avatar
Meat stick
Too far from them (AT&T)
Old Apr 9, 2008 | 04:34 PM
JaredGMS's Avatar
Meat stick
Why can we only have 1 gateway? If each DSL modem is setup on a separate phone line?
stogie1020's Avatar
Upgrading to load balancing can be several hundred dollars, depending on the model of device.
Old Apr 9, 2008 | 08:16 PM
brizey's Avatar
Do you think some of the problem is upload speed? You may be better off with a symmetric connection.
We use remote desktop a ton at work and we found that a T1 works better for us. It is really still DSL, it is just 1.5 up and down. The 1.5 down for us is fine. It's not like we are downloading porn torrents.
Old Apr 9, 2008 | 08:21 PM
brizey's Avatar
You have to tell your computer what IP address to send traffic that is not local (internet). It is usually your router's IP address, and most basic routers only have one WAN uplink.
Old Apr 9, 2008 | 08:25 PM
JaredGMS's Avatar
Meat stick
Each DSL modem is going to have a static IP.....
And even so, since they 're all on separate phone lines, how is it a problem?
Old Apr 9, 2008 | 08:30 PM
Beelzebub's Avatar
The problem is that you now have 3 static IP's for your internet connection and the machines connecting can only have 1 gateway.
If you keep them seperate, it isn't a problem but if you want them to talk to each other then you have to have a load balancer, which would have only 1 IP visable to you but 3 on the outside.
Old Apr 9, 2008 | 08:35 PM
brizey's Avatar
How will your router know where to send internet traffic? Most basic routers are set up for one gateway. Your router sits in between the WAN (public IP network) and your local LAN (private IP network). You internet gateway on your computer is you router's ip address. Your router logs onto your DSL service and it obtains its IP address on the WAN and its gateway to the WAN, which is your ISP's router's address. Basic routers can only do this with one DSL modem.
If you have three routers, one for each modem (for example, if the router is built into the modem), then you will have three separate local ip networks, one for each router. You can bridge them together, but it is work and more EQ. Another option is to use a managed switch that can load balance between the gateways (effectively, it is a sort of bridge).
All of this is pretty damn complicated for a six computer network.
Old Apr 9, 2008 | 08:49 PM
JLatimer's Avatar
Creepy guy in the mirror.
The term you are looking for is 'dsl bonding'
See...
http://digg.com/tech_news/How_To_Bon...s_Screenshots)
Also Netopia used to have some bonding products. Not sure if they do anymore - it never really took hold.
Old Apr 9, 2008 | 10:49 PM
JaredGMS's Avatar
Meat stick
It's not important that the PC's see each other. The only concern is that the bandwidth is increased.
Old Apr 9, 2008 | 10:54 PM
stogie1020's Avatar
You need a load balancing switch/firewall.
Otherwise, put each DSL line on a separate switch and only connect two computers to that switch. In that case, you will need a DSL Modem for each line, but the six computers will no longer be on the same network or able to see each other. All you will have is Internet Connection Sharing (basically).
Old Apr 10, 2008 | 10:32 AM
thunder04's Avatar
Sweet!
If that's the case, then what you want to do will work without any problem. :-)
When you speak of TS, are you connecting to a Windows Terminal Server via Remote Desktop Connection?
If so, have you tried bumping down the session quality? Under Performance, uncheck everything except "bitmap caching". Also, under Display, bump the color depth down to 256 colors. Also, I would turn off anything they don't need under Local Resources. I've been able to do RDC over dialup and it wasn't bad. Maybe this would make things more bearable?
Old Apr 10, 2008 | 11:14 AM
JaredGMS's Avatar
Meat stick
We've tried everything. It's still not enough bandwidth....
6 users on remote desktop + internet (necessary for bus) + 1 DSL line =
Old Apr 10, 2008 | 11:23 AM
AcUrAge703's Avatar
fios ftmw...and if not...cable would be faster than dsl
Old Apr 10, 2008 | 11:30 AM
JaredGMS's Avatar
Meat stick
And neither is available in our building.
Old Apr 10, 2008 | 12:05 PM
Will Y.'s Avatar
Registered but harmless
Is your office working in a converted Victorian or area where a T-1 can't get installed? Your office needs more than just DSL.
OK, that might be obvious...
Old Apr 10, 2008 | 12:08 PM
JaredGMS's Avatar
Meat stick
We can get T1, but my boss is unwilling to sign a 2-3 year contract.
I'm working with some major hurdles here, man
Old Apr 10, 2008 | 01:27 PM
stogie1020's Avatar
Give everyone their own DSL line and use sneakernet for file transfer....
Or use a VPN client and put everyone on the same VPN with their own DSL lines...
And eat some bacon sammiches!
Old Apr 10, 2008 | 01:29 PM
Whiskers's Avatar
Go Giants
Give everyone 3g modems....
Old Apr 10, 2008 | 02:11 PM
JaredGMS's Avatar
Meat stick
You don't seem to understand....this is the CHEAP way, so that's how I have to do eet
It sucks....there's not even any bacon in the building!!!
Old Apr 10, 2008 | 02:14 PM
Whiskers's Avatar
Go Giants
No bacon!!!!!!!!
Old Apr 10, 2008 | 03:55 PM
AcUrAge703's Avatar
Get an FTP Server....and use it to transfer your files on its own DSL Line...that way your not bogging down the usual network....and then put the user's on 1 DSL line....and find a 16gb flash drive...hire someone to upload the info to the drive then put it on the FTP server to send out....aka a tech...lol....i love my job...i really do...
Old Apr 10, 2008 | 03:57 PM
stogie1020's Avatar
I can get you a 10-UAL of Windows ME....
IBankMouse
Jun 13, 2020 12:53 PM
ceb
ILX
Sep 27, 2015 10:56 AM
gg0528
Sep 21, 2015 05:55 PM
Sep 17, 2015 09:01 PM
Sep 17, 2015 10:16 AM
