Auto generate a pdf file?
Old Apr 28, 2011 | 05:35 PM
sporting's Avatar
Is it possible to auto generate a pdf file from a batch file on a scheduler? If so how would I do it?
Old Apr 28, 2011 | 05:44 PM
stogie1020's Avatar
Needs more Lemon Pledge
Can you auto print from the batch file?
Try: NOTEPAD /P yourfile.txt at the end of the batch file.
Download and set PrimoPDF (or other Print to PDF creator) as your default printer.
You can do it in Wordpad too:
WORDPAD /PT yourfile.rtf MyPrinter
Prints it to the printer called "MyPrinter"
Old Apr 28, 2011 | 05:50 PM
sporting's Avatar
Have you done this and it works or is this a suggestion?
I would like to create a batch file and schedule it to run once a week to generate a pdf file. I'll see if that works.
Old Apr 28, 2011 | 05:51 PM
stogie1020's Avatar
These are legit commands.
What is the source of the data for the PDF? Is it generated BY the batch file?
Old Apr 28, 2011 | 05:54 PM
sporting's Avatar
The source is from Epicor Vantage CRM. The batch will run the Vantage to generate the report and hopefully print to pdf.
Old Apr 28, 2011 | 06:04 PM
einsatz's Avatar
I miss my 03 CL-S :(
If you know Java, it will be simple to code something up using iText
http://www.itextpdf.com/
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
malvothegreat
Sep 29, 2015 12:38 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
