Any Tips on Soldering Motherboards?
Old Aug 28, 2012 | 12:36 PM
Professor's Avatar
Карты убийцы
My daughter broke the power jack on her Dell. The part is on $1.50. But it is soldered in two spots.
Any advice on the type (silver, etc.) of solder and size and the heat of the solder pen?
Old Aug 28, 2012 | 12:49 PM
cM3go's Avatar
I would start with low heat, just so you don't burn anything, regular ol solder should work, its just power, doesn't require anything special. Be VERY slow and careful, use as little as possible.
Old Aug 28, 2012 | 06:39 PM
einsatz's Avatar
I miss my 03 CL-S :(
In addition to what cM3go said, I don't know what the part looks like but sometimes touching the part's contact point by itself with a little solder will heat up the contact point and apply a little solder to it, so you just have to tap it when it comes time to do the actual soldering, and the solder flows a little easier.
Old Oct 2, 2012 | 10:07 PM
Cruz_msl's Avatar
My Member is Registered
Start with a HOT soldering iron. After it's nice and hot, wipe the tip with a wet paper towel to get any contaminates off. Use a rosin core solder and melt a very small amount onto the tip of the iron. Touch the iron to the solder joint and let it melt around and through the board, about 3 seconds. Let it cool before touching anything.
Old Oct 3, 2012 | 09:00 AM
TeknoKing's Avatar
I spent years soldering; just have a plan in your head before you being and execute it with care, and remember, less is more... and I'm sure you've already done this it's been over a month, lol
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
ivan06106
Sep 26, 2015 04:38 PM
