TL-S Switchblades, Milled and cut from Heeltoe!
Old 01-08-2010, 11:15 PM
  #281
2006 DGP Sold 10/24/2012
Santa Rosa Steve's Avatar
Hi Marcus,
I just picked up an '06 TSX and would like to get one of your switchblades. After reading through your excellent instructions I'm left with one question: of the 2 master keys I have one is so worn that it barely resembles the other... hard to believe that they both work in the same lock.
What should I send off to you if I want you to do the whole package? Obviously the worn key is the one I'd like gutted for the chip, but since the edges are so eroded I can't see how it would work as a pattern for the cutting. I had the dealer cut a new valet key for me so I have 3 keys. Can I include that key for you to use and have it returned with the switchblade or do you require a master key for the cutting?
TIA,
SRS
Old 01-09-2010, 07:56 PM
  #282
Former Sponsor
MrHeeltoe's Avatar
It is much better to send the least-worn key you have. But if it both still work in the locks it really doesn't matter which you send.
I can work off the valet key, or if you feel like it you can send me both masters. I'll copy the cut of the better one and cut the chip from the worse one.
Old 02-03-2010, 02:21 AM
  #283
G SEDAN's Avatar
Just got this done through marcus.
Great guy, awesome looking keys.
Anyone in socal needs a programming hook up I might be able to help you
Old 02-03-2010, 09:32 AM
  #284
Former Sponsor
MrHeeltoe's Avatar
Thanks for the post dude!
Old 02-16-2010, 12:17 PM
  #285
MN-TSX's Avatar
2006 mdx
I have a 2004 TSX and I got a switchblade key for it a couple of years ago.
Now I would like to get one for wife's new (to us) 2006 MDX Touring.
Do you have the 2 button keys? Are they available with Memory function?
How do I order? I did not see an option for 2 button keys on your website,,, did I miss them?
Thanks!
Old 02-16-2010, 04:05 PM
  #286
Former Sponsor
MrHeeltoe's Avatar
I can do a 2-button version for sure. Are you able to program the remote buttons from the switchblade to the MDX? If so we can do this for you!
Old 02-18-2010, 10:13 AM
  #287
MN-TSX's Avatar
MrHeelToe
I was hoping you could tell me if the buttons could be programmed to work with an 06 MDX. You know a lot more than most about key/remote compatability.
I saw that the first page lists the 06 MDX as using the same key blank that you mill, but I did not find any other reference to an MDX as far as the buttons working. Am I the first to ask?
Thanks for any help!
Old 02-18-2010, 11:22 AM
  #288
Former Sponsor
MrHeeltoe's Avatar
I have not tried to so it is hard to say. But since you have a key and an MDX it should be pretty easy for you to test it!
Old 02-18-2010, 02:48 PM
  #289
MN-TSX's Avatar
I have an MDX, but not a 2 buttom swittchblade key (the TL-S key I have is for my TSX).
I thought maybe you offered the 2 button keys since they were on page 1 of this post, but it sounds like you could mill one if I already had one.
I guess I am the first to ask about a 2 button switchblade for an MDX.
Are you saying I could try to reprogram the buttons on my TSX(TL-S style) key to see if they work on the MDX, and if they do, that a 2 button RSX key would also work? If yes, can you supply the RSX key?
What type of key do the new MDXs use? Are they switchblade, and might they work?
Old 02-18-2010, 05:17 PM
  #290
Former Sponsor
MrHeeltoe's Avatar
The number of buttons doesn't matter, it is the frequency of the remote that matters.
Yes just try programming the tsx key to the MDX, see if it takes it! If so we can make a new place to order it online.
Old 02-19-2010, 08:11 AM
  #291
Twotone's Avatar
Doesn't the valet key have limited functionality for opening things in your car (ie glovebox). In the past that used to be the case in previous cars but I haven't tested it out on my TSX.
So my question to Marcus would be, if I send the valet key, will it be fully functional for opening all locks on my 06 tsx (manually of course)?
Old 02-19-2010, 11:36 AM
  #292
Former Sponsor
MrHeeltoe's Avatar
Yes it does, because it is thicker than the "normal" keys it does not slide into all the locks. But it has nothing to do with the cut of the key, so you can send a valet for me to copy, that is fine!
Old 02-25-2010, 06:33 PM
  #293
thinhthan's Avatar
so can i get one of these for my 99 tl?
Old 02-25-2010, 06:41 PM
  #294
crazyasiantl's Avatar
the key will work, however, the buttons wont
Old 02-26-2010, 01:16 AM
  #295
thinhthan's Avatar
well i want one where the key and the bottons work
Old 03-08-2010, 06:20 PM
  #296
CGP Ebony
xenonhid's Avatar
Thumbs up
Happy customer of the Heel Toe TL Switchblade key for my TSX.
It took a total of only 10 days from the day I sent it to when I got it back.
Keys fit, turned, and worked perfectly.
Would recommend.
I recommend sending in the valet key, since its least used and its easier to replicate the cut design.
Old 03-09-2010, 11:55 AM
  #297
Former Sponsor
MrHeeltoe's Avatar
Thanks for the props!
Old 05-06-2010, 06:40 PM
  #298
therealvtecfetish's Avatar
are the switchblade keys available for a 03 tl type s?
Old 05-08-2010, 02:46 PM
  #299
vancity67's Avatar
does this work with memory seats?
Old 05-09-2010, 12:20 PM
  #300
אני עומד עם ישראל
Hapa DC5's Avatar
Received my milled key. Works perfect, thanks Marcus!
Old 05-10-2010, 10:56 AM
  #301
Rumast21's Avatar
Hey MrHeeltoe
Just sent my payment and my stock key should follow along shortly.
Old 05-10-2010, 12:17 PM
  #302
are the switchblade keys avail for 03 tl type s? will the key work to start, open power locks and trunk?
Old 05-10-2010, 05:38 PM
  #303
Former Sponsor
MrHeeltoe's Avatar
The keys will work in a 2g but there is a problem with the remote frequencies. The switchblade will not open your doors with the buttons.
Old 05-11-2010, 09:07 PM
  #304
^hmmm...will the accord blanks work for my 03 tl then (open door locks and trunk?)?
Old 05-13-2010, 02:51 PM
  #305
Former Sponsor
MrHeeltoe's Avatar
No they have the same transmitters.
Old 05-15-2010, 01:30 PM
  #306
vancity67's Avatar
does it work with memory seats? cuz I have found some other ppl selling but they say it won't work with memory seats for 3g tl.
Old 05-17-2010, 04:43 PM
  #307
fz409040422's Avatar
Will this key work with Canadian model 06 TL? cuz my dealer told me there are some small differences, so they wont assure me if they can program it untill they try. And i wont be able to send my key in since i have only 1 set. Is there anyone have the Canadian model and works fine with this key?
Old 05-17-2010, 08:05 PM
  #308
Former Sponsor
MrHeeltoe's Avatar
Some other people are wrong. MY key works perfectly with seat memory. Cheap ebay ones don't.
I got your email but will reply here:
Yes it can be programmed in Canada the same as in the USA. It is the same key and programming process.
Old 05-17-2010, 08:37 PM
  #309
thx guess i will get my key a cheap copy and send it later this week or next week.
idk wth acura was thinking while honda gives accord a better looking key. both 3G TL and 7G accord were launched in 2004, and they are basicly the same
Old 05-18-2010, 03:15 PM
  #310
hi Marcus
i just placed my order, hope everything goes well
Old 05-20-2010, 04:44 PM
  #311
~HondaF1~
R J Poseidon 6's Avatar
Exclamation
Yes just try programming the tsx key to the '06 MDX, see if it takes it! If so we can make a new place to order it online.
Update?
Old 05-30-2010, 09:03 PM
  #312
do u have blank oem keys for my 03 tl? i would like to purchase 2 as well as have them cut and programmed.
Old 05-31-2010, 06:02 PM
  #313
bzyrice's Avatar
what is the turn around time to get this done? I only have one set of keys. I only got one when I purchased the car used. Also, I only have one set of the FOB to unlock the doors. How much do acura dealers charge to program it? I essentially want 2 sets of keys in case of emergencies. The switchblades and the stock ones it came with.
Old 06-04-2010, 06:00 PM
  #314
Former Sponsor
MrHeeltoe's Avatar
If you only have one key:
http://www.heeltoeauto.com/support/i...d=25&nav=0,4,5
You said you only have one "set" of keys. Does this mean you only have one key?
To get the cost from a dealer, call a local one and ask, since they all charge differently.
Old 06-04-2010, 06:04 PM
  #315
vancity67's Avatar
do u guys ship to canada as well?
Old 07-30-2010, 06:03 PM
  #316
Former Sponsor
MrHeeltoe's Avatar
Yes we do, all the time
Shipped 4 today, 4 more left in stock!
Old 08-19-2010, 11:48 PM
  #317
Former Sponsor
MrHeeltoe's Avatar
Bump! A complete new stock of keys is being machined now, order now to get in on the next batch!
Old 09-07-2010, 01:19 PM
  #318
Former Sponsor
MrHeeltoe's Avatar
Back in stock and shipping all backorders tomorrow!
Old 11-07-2010, 11:02 PM
  #319
University of Tennessee
Bladehopper82's Avatar
Hello MrHeeltoe,
I bought a switchblade from another member on here and was wanting to send it in to have it done. I was reading about you having the keys in stock? Is there a long wait time to have the keys done and are they in stock right now? I would be sending you the switchblade and my valet key. I would need it milled, possibly cut, and immobilizer swapped.
On a side note, my switchblade is a mem2, could I switch it with a mem1. If not, it's no big deal.
Thanks,
Old 11-09-2010, 04:55 PM
  #320
Got_3.2?'s Avatar
sick wish u could do this for an infini g35 coupe!
Quick Reply: TL-S Switchblades, Milled and cut from Heeltoe!
