Fastline Performance Adjustable Sway Bar POWERLINKS
Announcing the release of Fastline Performance's newest innovation,
ADJUSTABLE sway bar POWERLINKS!
![](http://fastlineperformance.com/images/mainlogo.jpg)
![](http://fastlineperformance.com/images/bg_flp_linkball_001.jpg)
![](http://fastlineperformance.com/images/bg_flp_linkball_020.jpg)
![](http://fastlineperformance.com/images/bg_flp_linkball_002.jpg)
Click here for all the details on this fantastic product:
http://fastlineperformance.com/powerlink.htm
![](http://fastlineperformance.com/images/bg_flp_linkball_021.jpg)
Regular price is $185 on these.
If we can get 10 people together for a group buy the price is $160
shipped each set!
WE ARE CURRENTLY AT 5 PEOPLE!
Added this product to heeltoeauto.com. I will be waiting to get 10
orders before I
ship:http://www.heeltoeauto.com/Fastline-...-pr-63060.html
When you check out, you will need to use coupon code "powerlinksfreesh"
to get the free shipping. International orders may be subject to
additional shipping fees.
Will be adding a BUY link on Heeltoeauto.com for you to make your purchases!
We will be adding your names as we get payments!
Marcus
949-295-1668
- Ease of installation: OEM links have only an internal hex on
the stud, severly limiting tool choice and placement when tightening,
and impeding sufficient torque input on the fasteners. The result:
clunks and rattles from the suspension, and increased likliness of
stripping. Fastline Performance Adjustable POWERLINKS provide multiple
square and hex points to effectively hold the link and stud in place
while tightening, in addition to an internal hex at the stud ends. The
nyloc locking nuts cinch down on thick 3mm washers. - Suspension Tuning: With conventional links, the sway bar is
always working to keep the control arms level. Even the simple act of
placing a driver in the seat will cause compression on one side of the
car and induce a pre-load on the sway bar, which will throw off the
balance of the car. As such Fastline Performance Adjustable POWERLINKS
will allow a tuner to preload the sway bar in the neutral state to gain
balance with the presence of a driver. - Compensating for Vehicle Lowering: When the vehicle is lowered
the orientation of the sway bar moves from its natural postion. This
movement can again induce an unwanted preload in the sway bar which will
adversely impact the neutrality of the handling. Adjustable POWERLINKS
will allow the tuner to move the sway bar into an ideal neutral or
preloaded postion independant from the height of the suspension. - Strength and Longer life: Fastline Performance Adjustable
POWERLINKS feature THK Ball Links over conventional ball-joints. Each
THK Ball Link is composed of a high-precision ball bearing, a die-cast
holder, and a shank connected to the ball by a special welding method.
Through a unique production process, the mirror surface of the ball
bearing is copied onto the inner mounting surface for perfect contact
between them, achieving outstanding wear resistance, exceedingly smooth
motion, and high strength. Capping off the ball is a special boot which
provides a tight seal against elements in addition to allowing a wide
range of motion. The result is the strongest and most efficient silent
link assembly available. - Corrosion Resistance: OEM links have raw steel studs and nuts
whcih are prone to corrosion and stripping. All components of Fastline
Performance Adjustable POWERLINKS are either non-corrsive aircraft grade
aluminum, stainless steel, or zinc-coated steel. - Improved Range of Motion to Prevent Binding and Bottoming:
Fastline Performance Adjustable POWERLINKS maintain their strength
through a much improved range of motion than conventional links, either
ball-joint or spherical bearing type. Binding is the cause for many
problems in handling at the limit. Cars with softer suspensions can
often bottom out the sway bar movement which causes the rate to increase
dramatically. This can cause handling difficulties or in worst cases
tearing of the sway bar mounts on the subframe. Fastline Performance
Adjustable POWERLINKS will allow the suspension to move freely to the
extent of travel, helping to prevent issues with binding or bottoming
out of the sway bar.
shipped each set!
orders before I
Marcus
949-295-1668
Will these fit an 03 Acura CL type S? If so add me to the list!
Also is this for all 4 links or just 2? Hope all four otherwise 4 would be way expensive! Seems like a great product though.
Originally Posted by Fulani has a TL
How do you place a pre-load using these?
Well put me on the list for one
1. Fulani has a TL
1. Fulani has a TL
Instructions are included. Just tighten and loosen using the turnbuckle link in the middle.
We are checking this weekend. It is for 2, and yes quality/high end parts are not cheap.
Originally Posted by onebadna1nsx
I wonder if these will work with the RL... I'll get back to ya when I lower my car
Originally Posted by Spiritman
When will these ship?
Once we start getting payments they should ship withing 1-2 weeks.
One question, so do we pay the 185, and then if you sell 10 or more we get refunded the difference?
Marcus
Man of God.....
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
Originally Posted by brianlin87
I'm down. Let's get this ball rollin'.
1. Fulani has a TL
2. brianlin87
3.
4.
5.
6.
7.
8.
9.
10.
1. Fulani has a TL
2. brianlin87
3.
4.
5.
6.
7.
8.
9.
10.
So why did you remove my name????????
![](https://acurazine.com/forums/images/icons/icon8.gif)
ASM I.S. Design FTW.
1. Fulani has a TL
2. Spiritman
3. brianlin87
4.
5.
6.
7.
8.
9.
10.
Better?
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Originally Posted by don5504
How about a backside shot of the head of the bolt. You know the only side of the endlink you didn't post a picture of.
D
D
I don't know what you are referring to. Can you describe differently?
Marcus
Marcus
Marcus
![](http://fastlineperformance.com/images/bg_flp_linkball_018.jpg)
And from the looks of it this is definately a quality piece. Thanks again.
D
Man of God.....
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
My fault. Must've overlooked your post. Not that it would take so much effort as to re-adding your own name, but I'll do it for ya:
1. Fulani has a TL
2. Spiritman![](https://acurazine.com/forums/images/icons/icon12.gif)
3. brianlin87
4.
5.
6.
7.
8.
9.
10.
Better?![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
1. Fulani has a TL
2. Spiritman
3. brianlin87
4.
5.
6.
7.
8.
9.
10.
Better?
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
![Screwy](https://acurazine.com/forums/images/smilies/screwy.gif)
![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
![Rolling](https://acurazine.com/forums/images/smilies/rolling.gif)
So whats the price? Add my name to the list
If we can get 10 people together for a group buy the price is $160 shipped each set!
2. Spiritman
3. brianlin87
4. Silvaccordex01
5.
6.
7.
8.
9.
10.
