Fastbrakes - Wilwood Brake Kits!!!
We have teamed up with Fast Brake Enterprises to bring you an inexpensive Big Brake Kit for many of you Acuraziners. The kits feature performance slotted and dimpled rotors, performance pads, brake lines, adapter brackets, and Wilwood calipers.
![Name: Wilwood20Superlite.jpg
Size: 7.0 KB](https://acurazine.com/forums/attachments/sponsored-sales-group-buys-10/85443d1501791993-fastbrakes-wilwood-brake-kits-wilwood20superlite.jpg)
There are two options:
- 12.6" 1 Piece Slotted/dimpled rotors with Wilwood Superlite 4 Piston caliper
http://store.excelerateperformance.c.../i-236893.aspx
- 13" 2 Piece Slotted/dimpled rotors with Wilwood Superlite 4 Piston caliper
http://store.excelerateperformance.c.../i-236894.aspx
- 13" 2 Piece Slotted/dimpled rotors with Wilwood Superlite 6 Piston caliper to come later - stay tuned.
The caliper is a 4 piston caliper like the Brembo caliper. The caliper on the 04-08 TL Base A/T has a 1 piston caliper. This caliper will have better clamping capacity and more equal dispersion of brake force.
Time to Climb
josh, please compare my rotora 1 pc bbk (s/d) with the wilwood 2pc 4 piston.
my rotora's still aren't installed and i would like to know how much weight savings i would get from the wilwood?
i'd imagine brake feel would be about the same?
Hi Josh, Do you have BBK kits (front and rear)for 3Gen TL type-s?
what is the price for 4 piston set and 6 piston set? and if it's not available from Wilwood then Rotora? oh and I have an automatic TL
TQ > MPG
Hmm, so how much of a spacer do you think? I really dont care because it will only be for winter. I have 03 CLS wheels, with the stock 55mm offset. Do you think a 1/2" spacer would do it? That would make the wheels ~ +40mm offset which is fine, heck even a 3/4" spacer would be ~ 38mm offset, which is ok by me too, just as long as the wheel doesnt look ghetto.
I Blaze Up In
Would the 2-piece 13" fit on a +40 offset wheel? I also found these http://fastbrakes.com/shop/product_i...oducts_id=1967, so would these fit stock CL-S wheels without a spacer???
-Mark
-Mark
