Keyed car :(
Old Oct 9, 2010 | 02:15 PM
teopeht's Avatar
Keyed car :(
Anyone know a place that can do paint repair to fix key damage? Haters gonna hate, but the blemish will make me insane.
Recommendations please.
Old Oct 9, 2010 | 07:35 PM
gotkilled's Avatar
NBP is a pain...
I feel your pain. Same thing happened to me a month or so ago...
Old Oct 15, 2010 | 11:25 PM
R2D's Avatar
R2D
fuck i feel you mane, some asshole just keyed my driver side door only!! if someone is gonna to something stupid at least do it right!! just finish it off and key my whole car....
Old Oct 16, 2010 | 12:47 AM
gotkilled's Avatar
NBP is a pain...
If anyone knows a cheap fix, let us know. I've been thinking about just filling it in with touchup paint by dabbing it here and there w/ a tooth pick.
Old Oct 17, 2010 | 12:16 AM
krnchunjae's Avatar
well... not a shop but i used dr.colorchip to fix my keyed damage and rockchips... worked fine and much better than touchup paint or nothing
Old Oct 17, 2010 | 03:29 AM
gotkilled's Avatar
NBP is a pain...
oo...ok, ill look into it.thanks
Old Nov 10, 2010 | 07:47 PM
bored7one4's Avatar
I feel you man!!! this happen to me two weeks ago.
try this
How- to repair a ‘keyed paint scratch
Vandalism is an unfortunate fact of life; waking-up to find that your automobile has been ‘keyed’ or scratched will quickly ruin your day. A body-shop repair will run into a couple of hundred dollars. A surface scratch that will `catch' your fingernail is approximately 0.04 Mil (1.0 µ) deep will usually require wet sanding and refinishing.
Use WD-40 (water displacement) until a repair can be carried out to protect the paint underneath the scratch
Put a drop or two of Woolite® liquid in a clean bucket and fill it with clean water. You will need 6-inch x 4-inch sheets of Nikkens™ 1000, 1500 and 2500 grit finishing paper Using a Unigrit Sanding Block and a small can of paint colour-matched to your vehicles paint
This method requires that you clean the surface with Isopropyl alcohol (IPA) and then apply paint to ‘overfill’ the scratch. Apply the paint in multiple layers allowing each layer to dry and remember "patience is the key"
Once the last layer of paint has dried (allow 12-24 hours dependent upon environmental conditions. Soak the finishing papers in a solution of water and a little dish washing liquid. Place the wet finishing papers on the sanding block and proceed very slowly, keeping the block perfectly flat.
Start with the 1000 git finishing paper and then use 1500 and finally 2000 grit .Take your time go slow and check progress often. You don't want to sand to deep or through the paint. No need to be aggressive eventually it will all become nice and smooth
The next step is to polish the paint surface to eliminate the ‘sanding haze’ and then a finishing polish to bring back the shine and finally a coat of wax or sealant for protection.
The smaller the scratch, the easier it is to correct it With practice this process becomes easier and avoids having a panel being repainted at a body-shop, along with the subsequent loss of using your automobile for a couple of days or more, plus the cost of which would run into hundreds of dollars
If your 'skill level' is not up to wet-sanding seek the services of a professional detailer
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
nanos
Nov 12, 2015 08:41 PM
jordanboi
Sep 5, 2015 01:33 AM
